Step 3Sheetfed Scanner
I've found that tiff is the best format for scans destined for pdf. Compressed or uncompressed doesn't usually matter. The files can be large, but Acrobat digests them well and the resulting pdf file is small.
DO NOT USE .JPG FORMAT!!! JPG uses "lossy" compression that fills your files with crap that can't be compressed. Use a real format like tif or gif or bmp from the good old days that isn't too smart for its own good.
New multifunction print/scan/fax machines often have a "scan to pdf" feature which might or might not do what you want. Most likely it'll use jpg format to slowly make large ugly files and then die.
You'll need to feed your book to the scanner twice, once for odd numbered page sides and once for the even sides. Do each pass into a separate directory. Then use a utility such as Thumbsplus to rename the scans so that when you put them into the same directory they'll be in the proper order. Then use Adobe Acrobat (the full version, not "reader") to assemble your files into a pdf file.
4
comments
Add Comment
Add Comment
![[RS] Knex rune defender](http://img.instructables.com/files/deriv/FGI/4LMP/FF8XAKCP/FGI4LMPFF8XAKCP.SQUARE.jpg)
