Introduction: How to Achieve Great Curls on Long Hair
Picture of How to Achieve Great Curls on Long Hair
Always wondered how to get those loose, big curls with your long hair? Look no further! It's an easy process that anyone can achieve! This instructuable will help you to perfect those bouncy waves that will look great on you!
Before we begin make sure you have the supplies necessary to complete this process. You will need one large barrel (1.5 - 2 inch) curling iron, several hair clips (whatever you feel will work to hold back pieces of hair while curling), hairspray and a comb. Now you should be ready to get started!
Step 1: Step 1
Picture of Step 1
For our first step make sure that your hair is in a clean, dry, and natural state. We want to work with hair that will hold curls so therefore hair that already has been styled with a hair iron (ex: straightener) will not be best. Instead begin this process fresh with just simply combed and dry hair that is ready to be curled!
Step 2: Step 2
Picture of Step 2
Now let's get ready to curl! Take your comb and begin to lift, along with your hands, the top and middle layer of the hair. Collect all of the hair around the crown of the head and now grab your hair clips. You will want to clip the pieces of hair you have just gathered, to the side. This makes it possible for you now to work easily with the bottom layer of the hair.
The only hair accessible and not clipped should be the bottom layer of the hair. We will work with this next!
Step 3: Step 3
Picture of Step 3
With the bottom layer of hair accessible, estimate about one or two inches of hair using your comb and hands to pull out this section for curling. Once you are holding the section take your curling iron and wrap around the top of the section of hair. You can choose to curl in or away from the face. The decision is yours!
Make certain however that you begin curling the hair from the top. Wrap the hair close to the scalp around the curling iron and hold for around 20 seconds. As this time passes loosen up the curling iron grip just slightly and pull the iron down slowly to gather more of the strand of hair. Hold the curling iron on this strand for as long as you feel is necessary. It usually is best to wait around 20 seconds. After doing this, gently remove the strand from the curling iron.
Step 4: Step 4
Picture of Step 4
After releasing the curl in the previous step you will want to make sure the curl stays in the hair. Take the hairspray you gathered with your other supplies earlier and lightly spritz the strand that you just finished curling. Avoid using too much hairspray just yet; we only use this quick spray right now to help hold the curl in the strand and avoid the curl falling flat.
Step 5: Step 5
Picture of Step 5
After spraying your first curl then continue on to curl the other pieces of the bottom, exposed layer of hair. Grab the hair located next to your first curled strand. Try to keep the width of the new strand approximate to the first strand. Again curl this hair from the top down and set the curl with a light spritz of hairspray. Do this to each strand around the bottom layer until the whole bottom layer of hair is curled entirely. Don't forget your hairspray spritz after each curled piece!
Step 6: Step 6
Picture of Step 6
You have successfully finished curling your first section of hair and now are ready to begin the process of curling the next section! Take out your clip holding back the top and mid layers of hair. If you would like you may choose to section off one side of the top/mid section, as you will be curling along the top layers now and this may be of benefit to you by breaking  up the section.
Step 7: Step 7
Picture of Step 7
Now we will be basically repeating what we did along the bottom layer of hair except this time for the top and mid layer. Take a piece of hair around one or even two inches wide from the top section of hair. Begin to curl starting from the top of the strand and working your way down with the iron. Spritz the hair lightly with your hairspray used earlier, after every curl is made. Continue to curl each strand in this area.
Step 8: Step 8
Picture of Step 8
Next unclip the top/mid layer of the hair that is pinned up currently. You will be curling this section of hair next.
Step 9: Step 9
Picture of Step 9
Again take one to two inch pieces of the hair and curl them from the top with the curling iron. After wrapping all of the hair to the bottom of the strand around the iron, release the curl and spritz lightly with hairspray. Continue to curl the rest of the sectioned hair you had just unclipped. By the end of this step you should have curled each piece of hair and section on the head.
Step 10: Step 10
Picture of Step 10
Now that you have curled all of the hair it is time for some last finishing touches. Using your hands and comb you can position pieces how you would like throughout the head. You may even choose to bring some curls to the front to rest on the shoulders.
Step 11: Step 11
Picture of Step 11
For this final step take your hairspray and spray the finished head of hair. Your completed hair should have bouncy, loose, large curls and give a full, thick, look to your hair!
You have just successfully completed this instructable on how to achieve great curls with long hair! Great job!
BarbaraL99 (author)2017-03-08
I have been using the karmin curling wand and works really well for my hair :)
Amyj14 (author)2015-09-08
ok this is fine but that is not really long hair, I have REALLY long hair and I have to have it down for a wedding, I needed some LONG HAIR help.
BreannaH4 (author)2015-07-04
I love it, it's basically what I had learned, I'm glad that other people get to learn this. I do have a concern though: my hair is roughly two and a half to two feet long :p I'm wondering if I could please receive some advice on how to get it to hold big curls. It's not terribly thick so that's a plus, not too thin, just right. But it doesn't like holding curls unless I do very small sections. Otherwise the curl lasts a few seconds, and even then the curls go limp and the only real curl is at the bottom. Should I spray before curling and a little when it's on the iron to keep the curl or should I only spray after? Any advice helps really. Thank you so much!
ParaH1 (author)2015-03-03
Thx for the great Instructable!!! I want to buy a hair extensions to make Curls, can you give some idea? pls give me a tips with message, by the way I am looking at this brand site named ParaHair, the link is http://www.parahair.com, pls adv!
CookieDemocracy (author)2013-08-07
I really enjoyed this Instructable. You did a great job at explaining the steps very clearly! You should definitely do more hair how-to's.
One question: How long does it take you to curl this much hair?
jentri (author)CookieDemocracy2013-08-07
Thanks so much! I really appreciate it and am glad you liked it! I find that it doesn't take me as long to do this now that I have found a way to go about it and have done it often. It also depends on how much hair you are working with. My hair is thick and a long length which takes me a half hour to 45 minutes to curl this way. Thinner/shorter hair does not seem to take as long. I would estimate about 20 minutes or so. I'm sure you'll find though that you will take a little longer at first until you get used to this process (sectioning the hair off, curling each section, styling once curled) and after that you should be able to do it pretty quickly. I hope this helps!
MyMenagerie (author)2013-07-03
Thanks for the great Instructable!!! I have hair about the same length, but in layers and can't wait to get that beautiful look!
Also, I am a little confused about the process. When you put the curling iron in her hair, did you place it near the scalp and wrap the ends of the hair around the iron?
jentri (author)MyMenagerie2013-07-03
Thanks! Yes, you can do it that way. I also find myself wrapping the curling iron around the hair near the scalp and slowly pulling/winding the iron down slightly which wraps more of the rest of the piece around the iron. Either way should work!
MyMenagerie (author)jentri2013-07-09
Thank you!
Maryvv22 (author)2013-07-02
The woman whose hair is being curled has the shiniest hair I've ever seen! How do you do it? Thanks for this instructable. You can use a smaller barrel curling iron also. My hair is so long that I curl the part closest to my scalp first and go half way down my hair. Then I release and start at the end of the first half curled. I hope that makes sense. Your method does produce "celebrity" worthy curls.
water rat (author)Maryvv222013-07-05
I WAS THINKING THE SAME THING!!!! Her hair is so shiny it shimmers! Please, you have to tell us what the treatment is called!
I haven't had long hair since elementary school. Short hair was not an option for my mom, but hair all down my back was. When I finally chopped it off I felt so liberated and free. Since then I've only gone between a pixie and a mid-neck bob, until a year and a half ago when my favorite hair-dude went a little nutso. I haven't had my hair cut since Nov '11 and now it's down to my bra strap. I have no idea what to do with it.
I've always admired other women's big loose curls, but have no idea how to achieve them myself. I'm going to have to try this one. Do you know if it would with curlers(?) and wet hair? My wrists tire easily.
jentri (author)Maryvv222013-07-02
Thanks! I really appreciate the compliment! Your technique sounds great. I will have to give that a try next time! Also, yes, she does have very shiny hair! She uses a treatment on her hair once a month which helps to achieve that result. Maybe that would be a good idea for another instructable? She will have to make one now too!
Thanks again!
Maryvv22 (author)2013-07-03
@Jentri Your welcome! A posting on how to achieve those shiny locks would be awesome. Keep up the good work.
About This Instructable
445,643views
112favorites
License:
More by jentri:How to Achieve Great Curls on Long Hair
Add instructable to:
