Step 4Further Modifying Your Reducer/Adapter (Continued)...
Now you will will to smooth off all the rough areas and scrap plastic, as well as level the edge on the wide end of reducer (Picture 3). Use whatever materials you have on hand for this; sandpaper by itself is quite effective. (I cheated and used a bench grinder.) You may want to use a utility knife to trim around the interior of each end of the reducer; just be careful, as the type of plastic used is quite soft and can be carved into (a little too) easily.
Don't try melting off any persistent rough plastic pieces with heat from a lighter, though. I found out that the plastic absorbs the heat and you get black marks on the surface.
Add Comment
