Step 3: Adding negative numbers
Adding negative numbers is slightly more tricky, but not by much.
Adding negative numbers is simply adding positive numbers in reverse. Instead of going up the number line, you go down it.
For example, 0+(-4)+(-3)=-7
And after that, it's exactly the same as for positive numbers, only in reverse.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
