Step 2Match pairs
They sum to 10. There are only five of these pairs so anyone who has spent a while doing maths should instantly recognise them, and they can make your life a whole lot easier when doing additions.
Take 13+27. Recognising the matched pair 3 and 7 in the ones place tells you the answer will be a multiple of ten, so you have to add 10, 20 and the 10 resulting from (3+7) to get 40- you have effectively simplified the addition from 13+27 to (1+2+1) * 10. Good for you.
If you become proficient at this technique, you may be able to combine it with the previous technique- if you saw 14+25 you might recognise that you can borrow a one to turn it into 14+26 then use this technique.
Pros: very quick, conceptually simple, quite general
Cons: requires practise for recognition, slightly limited application.
Add Comment
