loading
Step 7: Final Assembly
Then just insert all the parts into the housing and your customizable doorbell is complete. If you don't want the parts to be loose, you can fix them in place with hot glue or some other adhesive. To set the ringtone, just hold the microphone up to your computer speakers and press the record button as you play whatever sound file that you want to use. Then, whenever someone pressed the button on the transmitter, it will play your custom ringtone.
Design Notes:
The recording module that I used was not as loud as the original tone. So if you want to make it louder you can replace the speaker on the recording module or use it as the input to powered computer speakers.
Since the play button also functions as a stop button, the playback will be interrupted if someone presses the doorbell multiple times before the tone is finished. You can fix this by adding a capacitor between the recording module's ground and play pin. This will also help prevent stuttered playback that may happen with some wireless doorbells.
Rather than use the supplied microphone to record the tone, can I attach a 1/8" aux cord to record the tone straight from my iPod/phone?
Maybe. I don't know. I have never tried that before. If you try it let me know if it works.
Here is my doorbell board.
<p>You are using a plug-in door bell. The system that I designed was for a battery powered door bell. So I can make no guarantees about how it should be set up. The only thing that I could suggest is that you might get it working by connecting the negative wire to the emitter of the speaker transistor. So you would have one wire connected to the collector and one wire connected to the emitter. But I make no promises. Proceed at your own risk.</p>
I did it!! I ended up buying a battery powered unit. The sound quality is pretty bad. Is that due to the speaker that comes on the recorder or the chip itself? Would swapping out to a better/bigger speaker make a difference?
<p>Yeah. That is a pretty cheap speaker. Replacing it will improve the quality a little bit. But it will still be a mono wav file. So it won't ever have great clarity.</p>
I did get it to work! but for whatever reason, sometimes when I hit tecord, it would tell my phone that the &quot;war oh ones were diconnected.&quot; kind of a pain, but eventually timed it right to get the recording on there.<br><br>The issue I'm having now, is where to connect the negative wire from the 9v battery. My doorbell plugs into the wall, so there are no batteries. I've zapped 2 recorders by piting that wire in the wrong place. here is a picture of the circuit board. Should the (-) 9v wire be connected to the Hot or Nutral wire?
edit: &quot;earphones,&quot; not &quot;war oh hones&quot;
<p>Hi, I have a question about this. What 2 points on the circuit board would you jumper to make this doorbell ring manually? I do have the wireless doorbell button, but I need to find a way to &quot;manually&quot; jumper this circuit board and make the chime go off without the wireless button. I'm doing a different project that requires the chime to be triggered with a &quot;closed&quot; signal sent thru 2 wires directly to the circuit board, from one of my home automation devices (an I/O Linc). Basically all I need to do is find a way to manually jumper the board to make the chime to go off. Thanks in advance!</p>
<p>Each board is a little different. Send me a close up picture of both sides of the board on the doorbell reciever.</p>
I love this idea, great instructable! I did have a quick question, I'm working on transforming my front door from what it is now to look like the blue phone box from Doctor Who. Something like this would be perfect so that I could record the TARDIS sound and have it play when someone rings the bell. My only question is, how could I go about doing that so it sounds loud and clear? Either way I'll try your instructable and let you know how it goes. Can't believe there aren't more customize-able ones out there. Thanks again!
There are a few commercial version available but thet are a little more expensive,<br><br>Example:<br>https://www.google.com/shopping/product/11141394869277110590?q=mp3+doorbell&amp;rlz=1C1CHFX_enUS492US492&amp;bav=on.2,or.r_cp.r_qf.&amp;bvm=bv.48705608,d.aWc&amp;biw=1241&amp;bih=606&amp;tch=1&amp;ech=1&amp;psi=ncPTUeDADuTeyAHxo4H4Ag.1372832661395.3&amp;sa=X&amp;ei=p8PTUcffNKSuyQGLjYCQBg&amp;ved=0CFkQ8gIwAA<br><br>http://dx.com/p/wireless-mp3-doorbell-door-chime-transmitter-receiver-set-black-1-x-cr2032-3-x-aa-197511?utm_source=GoogleShoppingUS&amp;utm_medium=CPC&amp;utm_content=197511&amp;utm_campaign=1029&amp;gclid=CIP8vK_YkrgCFc8WMgodeRIA9g<br><br>http://www.hsn.com/products/swann-wireless-mp3-music-doorbell/6746305?sz=6&amp;sf=EC0463&amp;ac=INCEC0463&amp;cm_mmc=Shopping%20Engine-_-PLA-_-Electronics-_-6746305&amp;channel=Froogle&amp;mr:referralID=50729a72-e3a9-11e2-9389-001b2166c62d
Is this ripped from here? <a href="http://make.dozuki.com/Project/history/2867/now" rel="nofollow">http://make.dozuki.com/Project/history/2867/now</a>
I post all of my projects to Instructables, Make Projects, and DIYHacksAndHowTos.com
The author is just moving them over from Make and his personal website. :)
Congratulations on being a finalist in the DIY Audio Contest!! Good luck to you!
Thanks
You are a thief this project site? http://makeprojects.com/
That was a little embarrassing... :P
I see that you have come across my MakeProjects account. I am an active member of both communities and I post all of my projects to both websites. I appreciate your concern.
i liked th wooden box....i had the same doorbell and never thought to close it in a box....is neat.
This is a cool How to. The doorbell with the wood on the sides is a Heath Zenith 8-Note Melody Wireless Doorbell. I have one and that's why this instructable caught my eye. <br> <br>Frank
Hey, <br> <br>Could you give more details on the original doorbell? I've had a devil of a time finding a good one... <br> <br>thanks, <br>Scott
Unfortunately, I have no idea what brands or models that I used. I moved into a new house and there were two wireless doorbells there. The circuits were really similar in terms of how they activated the buzzer. So I assume that it is a pretty common design. The setup that I used will work as long as the ringer is using a transistor to short the negative terminal of the speaker to ground.
Great idea, and really so simple. Now add an amp to drive a larger speaker.
Can one just &quot;jumper&quot; the original speaker wiring to make the recorder play at a remote (additional) location (like the basement or laundry room)?
I used a wireless doorbell, so you are free to put it anywhere. But it would only work for one location. If you wanted to add a second ringer, you would need to get an additional receiver and recording module and then match the encoding combination on the receiver board.
Next step: RFID. Each family member gets a different ringtone, so you know who's at the door without a peephole! :-)
Wow!
This is great.
About This Instructable
69,783views
251favorites
License:
Bio: My name is Jason Poel Smith I am a Community Manager here at Instructables. In my free time, I am an Inventor, Maker, Hacker, Tinker ... More »
More by DIY Hacks and How Tos:How to Make a Festivus Pole Add Wings to an Infant's Halloween Costume Bubble Bath That Never Runs Out Of Bubbles
Add instructable to:
