How to Add Hazard Light With Switch for Scooter/bike
5,214
8
4
Posted
Introduction: How to Add Hazard Light With Switch for Scooter/bike
Hazard light is blinking all 4 side lights together. It helps greatly in bad weather conditions.
As my scooter didn't have the hazard light i thought of going through the DIY route.
My scooter is Honda Activa and hence this will work perfectly on honda dio , honda aviator, hero pleasure etc
Please note this method works well on an electronic flasher.It will not work on thermal flasher.
DISCLAMER:
Do not proceed any further if you don't know what this is all about. your warranty may be void by doing this.
I am not to be held responsible for any of your damage(s) if occurred under any circumstances whatsoever.
Step 1: Materials, Tools Needed
you will need the following things:
  1. Hazard light switch Button
    http://www.aliexpress.com/item/1pcs-Motorcycle-Swi...
  2. I have used the following flasher. it comes with adjustable flashing speed too.
  3. Phillips screwdriver
  4. Wire stripper
  5. hacksaw blade
  6. Insulation tape
    or any other form of insulation material will do.
  7. Common sense
Step 2: Prepare the Area
Have a close look at the area where you want to place this button. (you will have put a hole into the plastic dash.)
Check the image for an approximate idea.
then mark the measurements to drill a hole to fit the button.
P.S sorry I did't click pictures when i did this mod.
Step 3: Connection
The stock sidelight switch consist of 3 wires in case of my scooter.
The middle wire is power supply and the left and right wires are to carry current to appropriate right and left lights.
(NOTE: In case of 4 wires please find out the proper wires and connect accordingly.)
The hazard switch button consist of 3 wires.
use the wire stripper to strip little insulation from all 3 stock wires to expose the wire .
Now connect the hazard buttion middle wire to the middle wire of the stock wiring. similarly follow for the left and right wire.
Step 4: Test the Setup
Check if the connections are proper and then press the hazard button.
All 4 side lights should blink together.
once everything is set, use the insulation tape to cover up the new connection points made.
It should look something closed to as shown in the image.
DONE!!!!!!!
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    4 Comments
    This is a neat small mod. Indian Manufacturers have skipped a very basic function due to cost cutting.
    Thanks bhvm.. much appreciated :)
    This function is much needed and is kind of necessary for scooters.
