3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Add "Open with Notepad" to Right-Click
How to Add \"Open with Notepad\" to Right-Click
I personally hate to use "open with" due to the time, even if its only a few seconds, and having to then remember where exactly a certain program is located in my directory.
This will show you how to add ANY program to the Right-Click (Context Menu for all of your Files).
It's Easy, you cant screw it up, and it saves a bunch of time and hassle.
Since we will be dealing with regedit, and not everyone is familiar with it, i will be breaking down the steps to very simple, easy, and concise steps that anyone can follow.
Step 1First
First
Go to Start and open Run
24 comments
Nov 24, 2009. 6:38 PMNetDex says:
 Well, the program has to be in system32.
Nov 24, 2009. 6:40 PMNetDex says:
 If you want no path.
Jul 18, 2009. 1:34 PMwscottc60 says:
I suppose I should have tried it before I posted the question... It works Great. I Have LONG HATED that waiting thing. Thank you for this VERY handy bit of hackery. Scott C
Jul 18, 2009. 1:21 PMwscottc60 says:
Hi there and hello. I am guessing this would work for files with no extension but just to be sure I will ask you first... Can this "hack" be used to 'Open with' files with no extension? Scott C
Mar 18, 2009. 4:20 PMgoeon says:
sweet it wrks
Oct 13, 2008. 9:36 AMI3uckwheat says:
can u make it say open with firefox?
if so can u do it
Sep 25, 2008. 1:15 PMrandomguy96 says:
it says "cannot create key: you do not have the requisite permissions to create a new key under shell." what should i do?
Jun 7, 2008. 9:54 PMArbitror says:
I have Windows XP Media Edition and there is no shell fro the 5th step! There is only "OpenWithList" and "shellex"!
Jun 7, 2008. 11:49 PMMohamed Eltayeb says:
OK no problem! you can create it your self (Shell key)and then follow the rest of the steps...and it will give you the same result... For any extra-info contact me ..
Jun 7, 2008. 3:32 PMI3uckwheat says:
it doesn't work for me (not to complain) maby it because i have win 98
May 7, 2008. 3:43 AMmrmath says:
I just put it in my Send To menu. Also, I would put the %1 in quotes: notepad.exe "%1" Sometimes long filenames (C:\documents and settings\someusername\desktop\some file name.txt) get messed up, and you get error messages if you don't include the quotes. It may work without it, but I would add them because I'm like that.
Jun 4, 2008. 12:27 AMbrodyf says:
Thanks so much for mentioning that. I was having problems using a program in a different directory, and the quotes made it work like it was supposed to. What does that do anyway?
Jun 4, 2008. 4:53 AMmrmath says:
If the long file name has a space in it, some programs will consider it to be more than one parameter, as parameters are separated by spaces. So, if you want to open c:\some dir\some file with notepad, notepad c:\some dir\some file makes the computer thing you want to open a file called c:\some, a file called dir\some, and a file called file. Put it in quotes notepad "c:\some dir\some file" lets the computer know that it's one parameter, and that you mean that specific file.
Jun 4, 2008. 5:45 AMbrodyf says:
Well, that makes a lot of sense. I didn't realize that the "%1" was the placeholder of the path for the file to be opened. I have done very little with the registry. Thanks for the insight.
Jun 4, 2008. 6:16 AMmrmath says:
The %1 is the place holder for the first parameter sent. %2 is the second, and so on. Enclosing it in quotes makes sure that notepad (or any other app) knows that you really mean whatever is in the quotes to be one parameter.
May 14, 2008. 2:04 PMgamer says:
Really is no way to screw up, I didn't even have the "shell" key, so I made it, and then I followed the instructions and it works! Thanks for the great Instructable! -gamer
May 9, 2008. 11:18 PMrichelton says:
Cool. In the past I've always created a shortcut to notepad in the hidden folder x:\Documents and Settings\(userid)\SendTo
but this is more what I wanted. (Gotta love all the different ways to do the same thing, huh?)
May 8, 2008. 9:27 PMGarth Knight says:
Excellent. Works and explained well, thanks.
May 7, 2008. 11:53 AMNE-Phil says:
Hey, that's a wonderful instructable! I substituted another text editor for notepad that's also in the Windows path and it works like a charm. Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
60
Author:laminterious
