Introduction: How to Apply Fake Eyelashes
Faux Eyelashes are fun! But they can be tricky to apply if you have never tried to before. The following steps will walk you through perfect lash application, so you can glam it up whenever you feel like it.
Step 1: The Stuff
- faux strip lashes
- DUO lash adhesive
- liquid eyeliner
- powdered eye make-up
- mascara
- tweezers
- small scissor
- cotton swabs (not pictured)
For this Instructable I used the DUO clear adhesive, so that you could see it better in the photographs. I recommend using their dark adhesive, it blends more effortlessly into your natural lash line.
Step 2: Fit and Bend the Lashes
Often, your eye's shape will not be as long as the lashes you are trying to apply, it is important to trim them to fit your lash-line. If you have overhanging ends, they will begin to (painfully) peel up. Can you imagine how it may look to have your false lash falling off at your next party?
To fit Jessy's face, we fit the lash, and then trimmed about a 1/4" off each lash.
After we trimmed them, we curled each lash into itself using the strip adhesive that holds it to the plastic. I would let them set this way for about five minutes.....
Take this time to apply make up. Which brings us to.....
Step 3: Makeup!
I like to keep a pretty natural look. We brushed Jessy's whole eye with a nude town, and then ran a little bit of dark copper into the creases of her eyelids.
To help mask the look of the lash strip, I like to use a liquid liner to create a bold line along the eyelid's edge. Let it dry, and use a little bit of eye shadow on a cotton swab to blend it all in.
Step 4: The Glue
I apply the glue VERY sparingly. I allow the DUO adhesive to bead up at the end of the tube, and then just run the lash quickly through the bead.
If your line ends up too thin, then let it dry for about 10 seconds, and do it again.
DO NOT squeeze glue onto the lash strip, you will end up with a goopy lash strip that will not want to seat properly along your lash line. Instead, gently guide the lash along a bead of glue - this will ensure an even glue line.
Wave the lash around, and allow the glue to get tacky. You don't want to use wet glue, because it will just come off right away. I wait about 45-60 seconds before I start setting the lash.
Step 5: Stick the Landing
Ok, this is the hard part - but, not really. Have a cotton swab at the ready so you can tamp your lash into place.
After your lash's glue has become tacky, line up the strip to where you want to be placing it and gently rest it in that place. Using a tweezer dab at the lash hairs to begin getting the strip part to attach to your lid.
When you have a few tacky strongholds from the lash strip to your eyelid, take a cotton swab and start dabbing the entire length of the lash-strip. This will set the lash in place, push it down closer to your natural lash line, and help remove any extra glue globs. If you used too much glue, you may need to use multiple cotton swabs for this part.
Let the glue dry for about 10 minutes before you move on to the next step.
Step 6: Finishing Touch
Apply a little bit of waterproof mascara to help blend your natural lash into your new super-glam faux lashes, and you're all set! That wasn't too hard was it?
Have a different technique? Share it in the comments below <3
Also, POST PICTURES OF YOUR SUPERGLAM EYES IN THE COMMENTS, and if you learned anything I didn't list, and I will award you a 3 month pro membership
Beauty Contest
