How to Assemble a Computer
Published
Introduction: How to Assemble a Computer
this will help you to assemble a computer
Step 1: Getting Parts
you need to accuire
-cpu
-case
-optical drive
-ram
-power supply
-sata cables
-motherboard
-fans
-hard drive
-screws and stuff
Step 2: Get Tools
you will need:
- a scredriver (for flat head and philips screws)
-wire cutters
-pliers
-knife
-flashlight
-wrench
-screw container
-heat sink
-grounding strap
Step 3: Open the Case and Ground Yourself
open the case by removing the screws on the side plate
wear a grounding strap on your wrist and attach the other end to the computer case
the reason you would wear this strap is because it prevents damage to the computer by static electricity
Step 4: Install the Motherboard
first find the io bezel plate and install it onto the case
then install the standoffs into the case
then put the motherboard in having it aligned to the io bezel and screw it in
Step 5: Install the Hard Drive
push it into the slot it fits into on the case and screw it in when it gets far enough in
Step 6: Install the Optical Drive
-remove the part of the case covering them drive slot and slid the drive in making sure it is properly placed
-screw it in
Step 7: Installing the Cpu
you should find the proper way to orient the cpu first, some manufacturers do this differently so consult your manual.
orient it in the direction that it can be pushed down onto the slot
pull the rod on the socket up and push the cpu down
push the rod back down
Step 8: Installing the Ram
put the ram card on top of the socket, if the tab is in the wrong place turn the card around and it should be fine
push the ram into the socket and it should lock into place
Step 9: Installing the Heat Sink and Fan Onto the Cpu
put the heat sink on top of the motherboard and aligned with the screw holes
screw the heat sink into place
put the fan onto the cpu and lock it into place
connect the cable to the fan
Step 10: Installing Other Fan
install the case fan onto the mounting holes on the case
Step 11: Install the Power Supply
install the power supply into the case and tighten the screws
Step 12: Connect All the Cables
connect the cables to the sockets they go to
Step 13: Finished!
put the side of the case back on and turn the computer on!
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
