How to Assemble a Cthulhu PCB.
The Cthulhu PCB is a microcontroller based board made to go inside an Arcade stick so the stick can be used on a PC or Playstation 3 via USB. This board is available as an already assembled piece, or in a kit form for cheaper.
This Instructable will guide you through the assembly of a Cthulhu kit.
Step 1Identify Parts
Identify Parts
Before you get started, verify you have all of the parts needed to assemble.
The first picture below shows all of the parts included in the bare Cthulhu kit:
-1x 20 MHz resonator (Orange, three pins, '20MHZ' written on it)
-1x .1uF capacitor (Blue or yellow, two pins, '104' might be written on it)
-1x .47uF aluminum capacitor (Black cylinder, two pins, '.47uF' written on it)
-1x 10uF aluminum capacitor (Black cylinder, two pins, '10uF' written on it)
-2x 10 pin 10Kohm resistor network. (Black or yellow, ten pins, text written on it)
-1x 28 pin IC socket
-1x printed circuit board
-1x 28 pin PIC microcontroller (not shown)
The second picture shows two optional items as well:
-1x USB 'B' jack
-2x 10 pin screw terminals with 5mm pitch.
Both of these items are optional, but the USB jack is highly recommended.
If you have ordered an 'MC' (multi-console) Cthulhu, you will also receive:
-2x small glass diodes
-2x larger black diodes
Both are pictured in the third picture below.
12 comments
Jun 24, 2011. 8:12 AMpdoughboy says:
I have a 360 stick now that I'd like to use on other consoles. I found out this has Gamecube support but does it also have Wii support? I wanna use it on the Wii U, and from what I hear that will support Wii but not Gamecube acccessories...
Sep 11, 2009. 9:11 AMrasputan says:
would the 'MC' Cthulhu alow me to use a ps2 or ps3 controler on an xbox 360
Feb 22, 2009. 8:42 AMjoypad says:
what is this thing for????
Jan 23, 2009. 8:01 AMbase2john says:
Hi, great project! Is the PIC code available online, or for purchase? Would love to test it out. Thanks
Sep 25, 2008. 3:38 AMChaz-imus says:
Very nice Instructable! where might I find this kit for purchase?
Sep 22, 2011. 9:53 PMsharpfork says:
Can I still buy a DYI kit? The link above is dead.
Apr 15, 2009. 1:12 PMsparkfire says:
do you send to the uk or know of a supplier of these in the uk?? if so who?? if you do send, what is the price for a un-assembled kit with usb??
Oct 1, 2008. 6:39 PMPyrotechnic-Robot says:
This is sweet! Do you think you could get 2 of these and connect them together via a usb and then you could send 20 wires through a usb instead of 4?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:Toodles
