Step 2FPC connector and Resistors
iImage Information
The 20 pin FPC connector is the most important part of the entire AXISdapter. The ribbon cable that connects to the Playstation 3 gets inserted here, so make certan you which end the ribbon cable slides into. Take a peek at the board; all parts should go on the side of the board with the white silkscreened writing. Make sure not to put the pieces in the wrong side. The FPC connector should snap in place to the holes in the board. The bent pins of the connector should hold it in place easily. Doublecheck that the side the ribbon connector will go into faces the outside of the board so the ribbon will hang off of the end.
Take one of the two resistors and bend the legs close to the resistor. Insert the two legs through the holes for the resistor and pull them through as far as you can so the resistor is as flat against the board as possible. Once it is in all of the way, bend the legs to the side to hold it in place. Repeat for the other resistor.
