Introduction: How to Baby-Proof Sharp Corners on the CHEAP!!!
If you are a cheap-loving mama like me, and you've got a baby around the house, this project will save you some substantial cash compared to buying a baby-proofing kit from the toy store. You need a few simple supplies and only half an hour or so.
Supplies:
Plumbing foam pipe insulation (hardware store), preferably the self-sealing variety, but if not that's OK too.
Scissors
Duct Tape (I didn't need it, but it could come in handy.)
Supplies:
Scissors
Step 1: Cut the Foam Pipe Insulation
Here, you can see that the foam pipe insulation has a split down the length of the 6 foot long pieces that I purchased from the hardware store for about $2 a piece. Behind the yellow peel-away backing the foam is already sticky, which is handy for this project. It is meant to go around a pipe and stick to itself, so be careful to peel only one side at a time as you work.
First:
Figure out how long you want to cut your pipe. I wanted to make protective corners and then added pieces to go between the corners to cover the length of my coffee table. Suit yourself, it is pretty simple.
Next cut a V shape out of the middle of each corner, one on either side of the pipe. Be careful to leave space between these Vs to wrap around the corner. In other words, don't wind up cutting your pipe in half by mistake.
First:
Step 2: Apply Corners
Second:
Fit the cut pieces over your corner and then, carefully peel off the yellow backing leaving the sticky part on your table. Hold the foam carefully in place while working and then press to your surface to secure. If, for some reason, the foam does not want to stick to your surface, use a bit of handy-dandy duct tape to secure it.
I decided to add long pieces in between the corners, which is simple in comparison to the corners.
Voila! You have just baby-proofed your furniture!
