Ever wonder how Rambo can sneak up on his enemies, and slip away without a trace? Have you ever tried to sneak up on someone and they scared you, knowing you wanted to scare them? Have you ever tried to sneak out of your house and been caught? This  will give you instructions on how to be stealthy. If you read this and follow the directions you will hopefully be better at it next time.
I do not own these pictures, and do not take credit for them. All credit goes to the owners of the pictures.
Step 1: Control How You Walk
You should be walking in a crouched position, absorbing the weight of your body with your knees. You should be wearing soft shoes with a light rubber coating on the bottom, depending on the surface upon which you're walking. It all depends on the situation:
If you're in a house - Its best to use socks, as they are soft and they are comfortably fitting. When on stairs or on wood floors walk 2-3 inches away from the wall for this will bring creaking to a minimum.If you happen to be without socks and on wood floors, your steps have to be slow where when you pick up your foot, the moisture on your feet is silent. Consider rolling your foot.
If you are changing from, concrete to grass for example, you could make a sudden rustling sound. The best thing to do instead would be to actually find the gaps in the grass and stand on them, if you can't do that, I suggest rolling, just take a nose dive right in there, why not?
If you're in a place with lots of grass or leaves, its best to use socks or bare feet in these places. If you prefer water-shoes. Like in the house, the socks and/or skin of your bare feet help the impact from your foot to the ground, to be dampened. If you're worried about wet feet you can use water-shoes, but with these you must be extra careful! If they are soaked they can emit a "squish" type sound as your foot hits the ground. If you don't want your feet to get cut on weeds or rocks, you can wear multiple pairs of socks too.
If you're in a rocky place (pebbles, gravel, etc.) - You must use either socks or bare feet. No shoes! Soft socks and bare feet cushion the impact, but shoes will push the stones down and out, making the sound of rocks moving. When walking on this type of ground, you must absorb the impact with your knees, which should be bent. Tread lightly. However, if you step on a piece of glass and need an emergency, it will be difficult to come up with an excuse.
If you're in a place with carpet or any material like that- its necessary to use bare feet. because of the carpet, any stepping will cause the carpet to make noise itself, and no matter what, you will make noise. In this environment it is best to just over-exaggerate your movements and move even slower. it can also be good to find a noise to cover yours such as a refrigerator's hum.
triumphman says: May 15, 2012. 9:27 AM
come to my home and see what happens!
bobthebuilder728 (author) in reply to triumphmanMay 15, 2012. 3:21 PM
dont worry i wont come there
Paracord Ninja16 says: May 14, 2012. 3:19 PM
If you are out with some buddies playin airsoft or something and a car illuminates you ,you should NOT run because if it is a cop and they see you you will look very suspicous.
bobthebuilder728 (author) in reply to Paracord Ninja16May 14, 2012. 3:56 PM
airsoft in the street? never heard of it
Paracord Ninja16 says: May 14, 2012. 3:15 PM
Not many people no this (at least people I know) But actual Ninjas would wear dark browns, Purples, or blues.
bobthebuilder728 (author) in reply to Paracord Ninja16May 14, 2012. 3:54 PM
didn't know that, cool fact! i thought they wore black all the time. vote for me man!
james4 says: May 4, 2012. 3:40 PM
If you are hiding and spying or something like that if they catch you just say " i was playing hide and seek"
RSV26 says: May 3, 2012. 4:02 AM
if your body releses adreneln you should be able to breath softer.
bwrussell says: Apr 30, 2012. 2:36 PM
Carry a few dog biscuits, use them to distract and calm any dogs you may encounter.
If you are carrying more than one, lets say rock, for causing distractions don't put them in the same pocket or they will knock together.
Try to move when there is some other noise. A gust of wind, car driving by, plane overhead, etc.
If caught act like you know exactly what you're doing, be confident, calm, and act like you belong. This works best for trying to get into places you don't belong during daylight, hide-in-plain-sight, operations. i.e. VIP areas, buildings, etc. If you're caught behind the bushes in your neighbors yard it won't really work. A side note to this sort of sneaking is to dress well. People are much more likely to trust someone in a suit than someone in a hooded sweatshirt.
bobthebuilder728 (author) in reply to bwrussellApr 30, 2012. 4:10 PM
hey man thanks for all the stuff you told me, i credited you and spystealth. thanks alot. Any chance i can get a vote from ya? thanks again!
bwrussell in reply to bobthebuilder728May 1, 2012. 8:44 AM
No problem, votes in.
bwrussell says: Apr 30, 2012. 2:18 PM
Try to inspect the area you will be sneaking into/across during daylight hours if possible. This will help you see things that would be hard to notice in the dark and also give you an excellent idea of the lay of the land. A hose stretched across a lawn that could trip you, environment changes, pets, sight-lines, etc.
spystealth1 says: Apr 28, 2012. 6:55 PM
I want to add that you should ALWAYS have a excuse. Something like a fake note from a trusted, reliable source or some sort of explanation that could convince someone that you're innocent. Always decide on one beforehand and don't make it up on the spot. Pose as anything from a personal investigator to neighborhood watchman. (You get the idea.) Just make sure it fits your situation, and it helps to make them feel as if you're on their team. A well crafted fake identity can get you out of many bad situations.
bobthebuilder728 (author) in reply to spystealth1Apr 28, 2012. 8:58 PM
Thanks Man! I will add that
bwrussell in reply to bobthebuilder728Apr 30, 2012. 2:11 PM
You should probably credit spystealth1 since you quoted word for word.
bwrussell says: Apr 30, 2012. 2:10 PM
Being one solid color is often an easy way to be spotted, that's the point of camo. It breaks up your outline. I would also choose a long sleeve T-shirt because exposed skin is very noticeable.
Know your environment. In the forest vertical stripes can make you harder to spot since the tree trunks are also vertical.
bwrussell says: Apr 30, 2012. 2:06 PM
Breath with your mouth open. The narrow passage of your nose or slightly closed mouth cause the air to speed up and make noise.
Breath with your diaphragm not your chest, your chest should not really move when you breath. Not only is this better for you it's quieter. Also you can take less breaths breathing like that.
Scumm7 says: Apr 26, 2012. 8:24 PM
An additional tip: Count out the tempo of your target's pace and try to match it. It will help cover the sound of your footsteps.
bwrussell in reply to Scumm7Apr 30, 2012. 2:01 PM
But don't step at the exact same pace because it takes time for the sound to travel to them, you should step just before them. The further you are from them the earlier you need to step. When you get close only then match your pace.
bobthebuilder728 (author) in reply to Scumm7Apr 26, 2012. 9:18 PM
Thanks! I will add that!
Ranie-K says: Apr 26, 2012. 5:57 AM
Would be better if you used your own pictures. Are you sure you are allowed to used these copyrighted pictures here without properly crediting the picture owners?
bobthebuilder728 (author) in reply to Ranie-KApr 26, 2012. 3:01 PM
Im going to add my pictures later. the only reason was because it was raining where i live, and i wanted to get make sure my instructable got in.
bobthebuilder728 (author) in reply to bobthebuilder728Apr 26, 2012. 3:01 PM
if i do put in my pictures, will you vote for me?
Dusk Shadows in reply to bobthebuilder728Apr 28, 2012. 12:33 AM
sure and i already have=)
Dusk Shadows says: Apr 28, 2012. 12:32 AM
i were black leather anything that looks evil that's just my style
BTW i'm 12 and evil
The Cartographer says: Apr 27, 2012. 11:22 AM
Its probably best not to dress as if you were about to murder someone. I'd suggest something that you would wear out in public but making sure that its the colors of the area around you. Black will make you stand out more at night.
bobthebuilder728 (author) in reply to The CartographerApr 27, 2012. 3:06 PM
Yeah haha. I know dark blue is best for being out at night.
The Cartographer in reply to bobthebuilder728Apr 27, 2012. 4:10 PM
Indeed. Really dig the instructable btw, I might do something similar :D
Good luck.
bobthebuilder728 (author) in reply to The CartographerApr 27, 2012. 9:04 PM
Good Luck to you too!
bobthebuilder728 (author) says: Apr 27, 2012. 3:08 PM
Please Vote for Me in The Spy Challenge!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
