3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Become a Hypermiler
Step 11Pretend you have no brakes
If you didn't have brakes, you'd only go as fast as you needed to ensure you could stop at your next destination. That is, don't apply so much power that you'll only be throwing away your engery VIA braking.
Coasting is your friend.
6 comments
Oct 11, 2010. 11:23 AMmijhy says:
I must agree almost fully on this step. In any type of automobile there is a "peak efficacy" zone where the power required and drag created are balanced out evenly. Usually this is somewhere between 45 and 55mp (each car is different). Going faster does NOT mean your more efficacy. This is especially true in pickup trucks suv's and vans as they create an enormous amount of drag.
To reference the comment about jets, speed is certainly not the reason they are efficient. I wont go into a big debate on how a high bypass turbo fan works, but the efficient is due to the design of their operation not the speed at which they operate. Jets have the same "peak efficient" zone as any other mode of travel does and this is most defiantly not at full throttle. It is also worth stating the aerodynamic properties of the plane it self is just as much of a contributor to its efficacy than the engine its self.
But you still shouldn't impede other traffic just because you want to save 10cents at the pump.
Aug 22, 2007. 8:08 PMOutlander says:
Remember this "the faster one travels the less fuel one uses." The sole reason why jets are more efficient than prop planes, because they go faster. If a Jet consumes say 30gal/hr and takes only 1 hour to get from point A to B is only uses 30 gallons. If a prop plane uses say 15gal/hr, but takes 3 hours to get from point A to B, than it has consumed 45 gallons. Very simple really. The less time one spends worrying about driving like granny, obstructing traffic, and causing 5 O clock rush hour, the less fuel one will waste. especially when one has a .73 final ratio and 2.41:1 gears, 75MPH is much more efficient than lugging it out at 55MPH. Don't get a ticket!
May 30, 2010. 8:02 PMDamian7 says:
i used to drive most of time time at 65-70 mph where allowed and would get an avg. 30 mpg. I read a couple of articles about Hypermiling and tried simple things like slowing down(55 mph), rolling up windows, etc. Now I'm getting 35-40 mpg. I see cars flying next to me and I just think how dangerous and wasteful that is. I don't know a lot about planes or whatnot but it has worked for me.
Aug 23, 2007. 3:37 PMOutlander says:
Not the please for arguing from what I see, so I'll just say, look up the fuel consumption figures for a jet engine. Then compare those to a piston prop engine. You will find that the piston engines fuel consumption is much lower. It is a fact. Sorry. Is there a forum where this can be discussed? In cars, gearing determines at which speed is best to travel. On any automobile with say a final ratio of 1.0 with a 2.41:1 gear for example, of course 55 is going to be more economical to drive at. But if you drive anything made in the late 80's or after you have what is called an "Overdrive transmission" meaning you have a lower than 1.0 final ratio in the tranny. Like on my stang for example, 0.73:1 with a 2.73:1 ring and pinion. You said it yourself "the gas crunch" 70's 3 speed crappy fuel economy automobiles. I have been dealing with cars for about 7 years now and am ASE certified. I would be more than happy to discuss this peacefully in a forum.
Apr 9, 2010. 8:03 AMIfWeChoose says:
 Nice! I'm taking those classes next semester!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
324
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
