How to Become a Hypermiler
Step 6Pulse and Glide
Pulse and Glide
Assume you want to average 35mph.
Start at 40mph and allow your vehicle to decelerate, in Neutral, to 30mph -- this is called the glide.
Then, accelerate back up to 40mph in the same amount of time that your glide took -- this is called the pulse.
For the more intense, glide with your engine off. This will increase your FE number dramatically while gliding in gear will reduce them as you'll be combating engine braking.
This technique has been proven many times over to be an effective way to increase mileage. But, your mileage will vary based on traffic and other drivers. Other drivers will get quite pissed off at your pulse and glide, so use your best judgment.
21 comments
Mar 27, 2009. 7:13 PMcrispy010 says:
The reason P&G may get you better mileage at low speeds is because the engine is operating so far below its peak thermal efficiency when powering the car at those speeds. Put another way, the car has too much power. Peak thermal efficiency is, as I think was stated above, around 75-85% of full power. To get maximum mileage while still being able to cruise at highway speeds, all cars should have about 65 hp (in general, it takes 30-50 hp to cruise at 65-70mph). However, turning your car OFF while moving is a BAD idea. When the car is off, your power steering and brake boosters no longer function. This essentially means your car becomes a 3000 lb uncontrolled brick on wheels. Please DO NOT turn your car off while moving. Shifting into neutral will get you most of the efficiency benefits. Additionally, turning your car on repeatedly will wear out your starter motor, battery, and electrical system - they are not designed for that many cycles. Even in hybrids such as the Prius, the gasoline motor is "bump started" instead of being turned over by an electric motor.
Sep 14, 2009. 1:50 AMvandal1138 says:
People also don't realize that the amount of gas utilized in starting the motor is greater than leaving it running for the time being, so unless you are coasting down a LOOOOOOONNG hill, you're wasting gas by shutting off the engine and starting it back up again.
Sep 22, 2011. 9:22 AMxaenon says:
The rule for carbureted models, if I remember, was 'shut it off if you're going to idle more than about five minutes' - the five-minute figure being based on the idea the engine would use as much fuel at restart as it would 'waste' idling for five minutes. All assuming, of course, that everything was working as it should, which with carburetors, was not all that often the case.
With modern fuel-injected cars (port-injected in particular), the amount of fuel required for restart is far, far less - enough that you'll actually save fuel if you shut it off and restart it when needed, rather than let it idle for TWO minutes.
Sep 26, 2009. 6:54 PMV-Man737 says:
Really old cars use a lot of gas on startup. More recent models (1996+, I think) have really cut back on that. Turning off your engine is quite effective, if it is new.
Jan 29, 2011. 12:44 PMDude567 says:
Yes but in the first 90s of your engine running 75% of the pollution is emitted because a cold catalytic converter is not very efficient
Jul 7, 2011. 2:29 PMac-dc says:
It's not going to be very cold, there aren't long enough periods the engine would be off for it to cool down that much, and if you were implying that it takes 90 seconds to warm up, no it does not, the thin honeycomb structure in any recent vintage cat. converter heats to temperature far faster. For once, greed on the part of manufacturers to reduce the amount of costly precious metal in a cat. resulted in several useful gains.
Modern engines can be designed so that their emissions stay within EPA mandates for pollution, haven't you noticed some street legal cars now do shut off their engine when they are stopped (stop light, etc.)?
Jul 22, 2011. 8:31 AMswander says:
This is a joke. If you dont have a hybrid or electric car, this pulse and glide is a wash. Take a carbureted car for instance: Every time you mash the pedal, you are squirting up to 80cc of raw fuel into the carb (Holley 850 DP with 50cc pump on rear) This is an extreme example but it is a valid concern. This fuel is way more than is needed to combust so you get the telltale black puff out the rear. Keeping a steady rate will net more mileage than this dangerous illegal practice of turning the motor off or varying your speed 25% on a shared road.
Oct 11, 2010. 11:08 AMmijhy says:
As a professional driver, i thought i would add my 2cents to this particular step. While they are obvious benefits of "coasting" I want to point out it can also be very dangerous. In a winter climate much of the control you have over your vehicle is from your engine, disconnecting it from your wheels leaves you no chance to correct a slide if you get into one. Yes you could only do it in summer, but once you fall into a familiar practice it would be all to easy to repeat it with out thinking, and then when your in a ditch or upside down you realize that 1% gain in fuel efficacy wasn't worth it. There are some comments about brakes going down hills, well of coarse you have to break, but what if you coast to a stop light, forget your not in gear, and roll back into another car. Every state is different on passenger cars, but it is federal law, that any commercial vehicle never be out of gear for more than a few seconds (time to shift). Again its only my 2 cents, but it is something to keep in mind.
Jul 7, 2011. 2:33 PMac-dc says:
while using powered traction to get yourself out of a slide works for professional drivers, the average person on the road tends to overcompensate trying to do so and ends up that much worse out of control than if they only concentrated on steering and braking.
Aug 19, 2007. 7:31 PMreddeth says:
It takes a lot of power to get up to 40 MPH, even going from 30, this glide on/off idea is not only dangerous, but cannot stand to be truly effective, you're using a lot of an engines power to make it back to 40 MPH, this may be different for electric/hybrid cars running on the electric motors, which in turn use deceleration and braking to generate more power but on a traditional gas powered car this would not be a productive enough maneuver to outweigh the danger you present to other motorists by the constant accelerating/decelerating.
Apr 25, 2011. 1:30 PMDude567 says:
Yes, but the laws of the universe require that one day all drivers will have to deal with a tailgating jackass, trying to save a little on has fuel bill. And, personally, an acceleration is physically more difficult than maintaining speed. Ever ridden a bike? Then you know what i'm talking about.
Aug 19, 2007. 10:27 PMreddeth says:
I still find it questionable, but this isn't a forum for discussion, thank you for the link, thats all I'll say on the subject.
Jul 7, 2011. 2:20 PMac-dc says:
The correct answer is that for most vehicles pulse and glide results in worse fuel economy. It only helps with specific vehicles, most of which are hybrids.
The problem is the method was suggested as if it applies to any vehicle (by omission of vehicle parameters necessary to benefit from it) when for "most" people it is worse because most people don't own applicable vehicles.
Apr 25, 2011. 1:33 PMDude567 says:
Engine on clutch off you are technically getting 0 mpg to be useful that data should be gph crossed with the coasting time and distance moved while coasting. Call me when THAT'S been calculated.
Aug 11, 2010. 12:17 PMjimmytvf says:
yes, is effective in save money in gas, but it doesn't if you have to buy new brakes. is going to be more expensive the brakes than a few ml. of fuel.
Aug 11, 2010. 3:02 PMjimmytvf says:
i'm saying that because in downhill the engine make a little inertial brake, and if you turn off the engine, that inertial brake won't work and you have to apply more brakes. in flat surface will work good ;)
Mar 18, 2010. 6:05 PMAchan20 says:
lol. can you even drive that car...... because i would...... haha
May 9, 2008. 11:21 PMRishnai says:
Seems to me that it would be more efficient to smoothly accelerate to cruising speed where you can have a nice low rpm at a steady speed, no revving up and down. Depending on your gearing, that might be 30 or 40, not 35, but it's a big factor.
May 15, 2008. 10:06 PMslurp812 says:
I know it seems that constant speed is better, but the motor is more efficient when given around 70% throttle. I was testing this out myself with my scangauge II today. 37.6 mpg (20 mile trip including expressway) is not bad for a car rated 26/30. I actually got better mileage when I got off the freeway, and pulsed/coasted the car...
May 11, 2008. 9:24 PMRishnai says:
I've got an idea: let's test it with a car that automatically computes its milage, and see what's the better approach. Crazy as it sounds, your pulse-and-glide approach might actually be quantitatively superior.
May 12, 2008. 7:41 PMRishnai says:
Well, I stand corrected. My apologies. And thank you for the link, it was quite interesting.
Aug 22, 2007. 7:34 PMOutlander says:
This step does work, but at a cost. The cost is that engaging and dis-engaging the clutch on and off, on and off, on and off, over and over will wear out the clutch disc, the slave and/or master cylinder much quicker. Simply costing up to a speed say 65mph, than dirfting without using the clutch will help save on gas. Only put the clutch in if one can coast down a hill, or maintain more than a few seconds of time before one needs to "pulse" again. In an automatic, switching between drive and neutral all the time will destroy the transmission, no question or if's about it. Hope the fuel economy out weights the repair costs, cause on my mustang it sure doesnt. Even though I have gotten 30mpg highway by using the "pulse and glide" method, the repairs are more expensive.
Aug 23, 2007. 4:07 PMOutlander says:
1995 ford Taurus. Destroyed it when I switched from drive to neutral while driving. At least it was under warranty. ASE certified, have rebuilt GM TH200C's TH200-4R's TH350's(a real POS always drops 3rd gear) throwing the trans out of gear and back into gear will destroy it, at worst you will wear the bands and clutches out early, possibly even blow out a seal from the rapid increase of pressure and drop a gear(200C). Also playing with the overdrive(on off, on off) with kill a trans as well. For an example, abuse the neutral to drive until you wear out the trans, take it apart and see what you find. On a manual, if you have ever had to change a clutch set( raise the car on stands, remove the driveshaft, then the mounting hardware, then the trans, then the clutch, then the flywheel) you will understand the grief and pain of swapping a out a clutch and finding someone to resurface the flywheel. Take it from a mechanic, this method is not all what its cut up to be. Especially if all you have to do is replace a stupid $20 throwout bearing, a real nightmare. Automatics are MUCH easier in terms of maintenance.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
314
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
