How to Boot Windows 7 in a USB Drive (Windows PE LiveCD or LiveUSB)
Published
Introduction: How to Boot Windows 7 in a USB Drive (Windows PE LiveCD or LiveUSB)
About: My Name is Putra Adriansyah , I'm from Ptrsoft Developer Team. I'm not good at english. so , I'm sorry if my english is bad
Windows Preinstallation Environment (also known as Windows PE and WinPE) is a lightweight version of Windows
used for the deployment of PCs, workstations, and servers, or troubleshooting an operating system while it is offline. It is intended to replace MS-DOS boot disks and can be booted via USB flash drive, PXE, iPXE,[1] CD-ROM, or hard disk. Traditionally used by large corporations and OEMs (to preinstall Windows client operating systems on PCs during manufacturing), it is now widely available free of charge via the Windows Automated Installation Kit (WAIK).
Contents
WinPE was originally intended to be used only as a pre-installation
platform for deploying Microsoft Windows operating systems, specifically to replace DOS in this respect. WinPE has the following uses:
Deployment of workstations and servers in large corporations as well as pre-installation by system builders of workstations and servers to be sold to end users.Recovery platform to run 32-bit or 64-bit recovery tools such as Winternals ERD Commander or the Windows Recovery Environment (Windows RE).Platform for running third-party 32-bit or 64-bit disk cloning utilities. The package can be used for developer testing or as a recovery CD/DVD for system administrators. Many customized WinPE boot CDs packaged with third-party applications for different uses are now available from volunteers via the Internet.
The package can also be used as the base of a forensics investigation to either capture a disk image or run analysis tools without mounting any available disks and thus changing state.[2]
Version 2.0 introduced a number of improvements[3] and extended the availability of WinPE to all customers, not just corporate enterprise customers by downloading and installing Microsoft's Windows Automated Installation Kit (WAIK).
It was originally designed and built by a small team of engineers in Microsoft's Windows Deployment team, including Vijay Jayaseelan, Ryan Burkhardt, and Richard Bond.[4]
Step 1: Files That You Need to Make Windows 7 Able to Run Without Installing
First, Read this to know What is Windows PE
"Windows Preinstallation Environment (also known as Windows PE and WinPE) is a lightweight version of Windows
used for the deployment of PCs, workstations, and servers, or troubleshooting an operating system while it is offline. It is intended to replace MS-DOS boot disks and can be booted via USB flash drive, PXE, iPXE, CD-ROM, or hard disk. Traditionally used by large corporations and OEMs (to preinstall Windows client operating systems on PCs during manufacturing), it is now widely available free of charge via the Windows Automated Installation Kit (WAIK)." (from Wikipedia)
Ok, so, This is the tools that you need to make Windows PE :
1. Make_PE3 or Winbuilder
2. Windows 7 Installation CD
in this Instructables, i will shows you how to use Make_PE3 to create Windows PE
Step 2: Mount the Windows 7 ISO
Now, You need to Mount the Windows 7 AIO file to make the Windows 7 PE
(Right-Click to the ISO >then> PowerISO >then> Mount to Drive (your poweriso virtual drive, ex: Mount to Drive G: )
Step 3: Setting Up "Make_PE3"
After you Mount the ISO Image, then you need to Install the Make_PE3 Program (or you can call it builder, creator, etc)
NOTE :
Please make sure that you Extracted the "Make_PE3" Application in your C: Drive to make this program working Correctly
and you will see the files (see the extracted picture)
Step 4: Let's Make It !
set the program like this :
~Windows 7 Source : Windows 7 Source is Your Mounted Windows 7 ISO Image that where the required files will copied to Working Directory
I Recommend that you keep the defaults in Architecture setting , WINDOWS AIK Tools bla bla bla settings
ok , then you Change the "EXP" to Whatever you Want (Keep it to EXP , or BS or MIN or Media)
after that , you can enable if you want to add "Adobe F" or "NetFrame"
Step 5: Click "GO" and Waiting !
After you do all Previous step , then you can Click "GO" button to Make the ISO
you can do something else to wait the progress to complete
i listening to music while the progress do the task :D :D :)
Step 6: Finishing and Finding the ISO Location
After the Progress Complete, you will see "End of Program bla bla bla" Window (Read and Click "OK")
When you find the ISO, You can find it at "C:\Make_PE3\win7pe_x86" or Click HERE (if you make x86 build, i build the x86)
LOOK !!! The ISO is 304 MB Sized !! :D :D , as in the Wikipedia Said "Windows PE is a Lightweight version of Windows)
so it's not strange if it 304MB sized :)
Step 7: (Not Too Required) --> Test in VMWare !
Look It's Running :D :D Now you can Backup your Data in your Harddisk Before you Reinstall your Device !
Just Boot it From CD or USB (i recommend USB) (Make the USB Bootable using Rufus, find it yourself!)
and Backup your data :D
even in a computer/laptop that doesn't have any OS (or Not Installed yet) , the WinPE is Working correctly
i have test it for :
~Listening Music without OS (Using WinPE USB)
~Watching a Movie
~Chating (connect via WiFI)
~Ngaheureuyan batur (Sundanese for "Pranking my friend")
~Re-Installing Windows + Watch Insidious 3 (i added MPC to my WinPE) + Chatting at a same time
etc
Thank for Reading my First Instructable ! :)
find me at Facebook : Putra Adriansyah >> (NOTE That My name is Putra Adriansyah , Not Bob Felix Ralph , it's a Fake Name !!)
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    9 Discussions
    Thank you boy
    It was very helpful
    I have question that can i run microsoft office word on live windows
    I know we can install softwares in live mode of linux
    Can we do it on live windows
    this is best step for boot windows 7 in usb
    http://getintoopc.com/
    ajit24
    2 years ago
    Its a very good tutorial i was looking for anyway i have downloaded portable software from this site
    http://www.webforpc.com/
    and its working fine
    GrodS1
    2 years ago
    Nero Burning ROM 2016 gives you a chance to copy CDs, DVDs and Blu Ray circles on
    your Windows PC. The product was initially discharged in 1997, and it has
    developed in accordance with clients' changing requests over very nearly two
    decades.
    The
    most recent adaptation bolsters a few incarnations of Windows, from Vista
    directly through to Windows 8. (There's likewise a sister item for Linux
    machines.) The item's designers guarantee that it underpins each make and model
    of circle burner on the planet. Be that as it may, Nero Burning ROM does
    exclude the broad media administration elements of items like Nero 2016
    Platinum.
    GrodS1
    2 years ago
    decades.
    The
    Platinum.
    Hello! I was looking for this certain info for a long time.Thanks and best of luck.
    http://getfullcrack.com/avg-internet-security-2016-crack/
    Awesome Tutorial
