HELLO! My name is Alex and this is my first instructable WOO!
Today we will be learning some of my techniques for breaking in a baseball glove. Since the turn of the last century people have been playing baseball for leisure or professionally. And as a player, one of the common things I hear from fellow team mates is the "stiffness" of a new glove. Believe me I'm a catcher, and some of the worst gloves to break in are catchers mitts. It also seems that the newer and higher quality of the glove the harder the darn thing is! So now *trumpets and drum role* I will be showing you how I work my magic on my mitts and fielding gloves to make them soft and pliable.
Remove these ads by
Signing UpStep 1Beating Your Mit
Materials: One Hammer (recommended: ball peen or rubber mallet)
OR
Glove Mallet
Hammer:
If you choose to use a conventional hammer I suggest you use something with a more worn down head. With sharp edges comes scratches, scuffs, and ultimately tears (on your brand new glove). I like ball peen simply because it has the rounded side making it a little gentler.
Rubber Mallet:
I also recommend using a rubber mallet. The soft rubber head makes for almost no scratching. But be careful as over extended use of this mallet or using a cheap-er mallet may cause scuffs on your brand new mitt.
Glove Mallets:
There are various types of glove mallets from home made to retail. They usually have a stick like apparatus for you to hold, with a ball shapped orb on one end. You then take the stick and proceed to beat your mitt.
Technique: There are various techniques to this step. I prefer the Inside Out method.
Take the glove. Turn it inside out, so that if you were to wear it you would have to catch the ball on the side opposite where you would normally catch it. Then take your hammer/mallet and go at it.
17
comments
Add Comment
Add Comment
