3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build A Custom PC: The Complete n0ob's Guide to Building a Computer
Step 5Installing & Connecting the Drives
  • last photo ←
Any 5.25" optical disk drive fits into the 5.25" drive bay, or the front section of the computer case. The hard drive, though, is connected in the lower drive bay (3.5") as opposed to the upper part where most internal drives are located. If you want to use an old school floppy drive, you'll most likely need to secure it in the smaller drive bay as well. The most common form of securing these in place is by using screws on either side of the drive bay.
To do this, you will need both case covers off so you can reach both sides of the drive bay. Simply slide the drive into place, whether it be DVD or CD, line up the screw holes with the holes on the drive bay, and tighten the screws in place. In my demonstration, I only use fours screws per drive.
As for connections, the white connectors with four large holes in it them are the power cables that plug into the optical and hard drives. Also plugging into the hard drives are ATA data cables (either serial, which are the small black cables, or parallel, the older wide cables)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:technick29
