3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build Custom Speakers
Step 16Install the crossovers inside the cabinet
Use hot glue, screws, or construction adhesive to install the crossovers inside the speaker cabinet. Put the heaviest crossover on the bottom and try to orient inductor coils at 90 degrees to each other to limit electromagnetic interference.
Pull leads into position through the terminal cup and into the area where the drivers will be mounted. I tie the speaker wire leads around the holes in the mounting bracket to reduce/eliminate wire tension that would be transmitted to the drivers and the crossovers in the event of a tug or snag.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
891
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
