3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build Custom Speakers
Step 9Glue the cabinet sides together
  • last photo ←
The first part of the cabinet to be assembled are the sides, top and bottom. The front and back go on later.
Before gluing up the cabinets I lay everything that I'm going to need out on a large flat level surface. Once the glue bead gets laid down, the clocks ticking, so you'll want to move with some speed and efficiency. Having an extra set of hands for the step really helps, but it's not a necessity.
Lay a thin bead of high quality wood glue (I like Titebond myself) along the edges of all adjacent sides. Be sure to spread extra glue inside the holes for the biscuits. I use a chip brush to paint the glue into position and spread the bead evenly into a 3/4" strip.
Insert the biscuits into the slots, being sure to push them all the way down. Any biscuits that don't easily fit into the slot should be discarded and swapped for a new biscuit--sometimes the biscuits swell slightly due to moisture and humidity.
With the biscuits in place and glue on all of the adjoining surfaces, it's time to assemble. Join edges to faces and construct the cabinet.
I use many many clamps to pull the cabinet tightly together and apply uniform even pressure to the joints.
With the edges glued and the clamps loosely in place, now's the time to square everything up. Using a tape measure and the clamps, measure the diagonal from corner to corner of the square you've just created and adjust the clamps until they are equal. This means that the box is perfectly square. See the photos below.
Before the glue sets up, it's also a good time to make all of the panels flush with each other. Use a dead blow hammer and a block of wood to knock all edges flush.
Apply a sufficient amount of clamps and wait for the exterior walls of the cabinet to dry. As you can see from the pictures below, pipe clamps are great for this purpose, and if you've been needing an excuse (or two) to buy some, 42" tall tower speakers are good ones.
1 comment
Oct 24, 2010. 4:41 PMmpikas says:
You're the first person that I've ever seen use biscuits... I'd probably try it if I had a biscuit cutter.
Most people use drywall screws, which is fiddly and ugly, and unless you predrill everything you're just asking for split pieces and stripped holes (If you're going to do that at least use coarse threaded drywall screws).
I usually use glue and 18ga brads (2" unless there isn't room for some reason). You get a tight fit up, hold incredibly well (try pull one out that you missfired, it's just about impossible) and a clean look, and I bet that assembly is MUCH quicker than with biscuits. I even have some boxes that ended up bare MDF covered in tung oil and once you sand them you can't see the brad holes at all. Another advantage with them is that they are so thin and soft that metal working tools, saws, router bits... will cut right through them without catching or dulling, so even if you fire one through an area which will get cut later they don't get in the way like screws will.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
886
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
