How to Build Custom Xbox Glow Speakers
514
10
Posted
Introduction: How to Build Custom Xbox Glow Speakers
Speaker Build Provided by 123Toid - https://www.youtube.com/user/123Toid
Step 1: Cut Your Cube Shape
Cut out 7.5” x 7.5” front and rear baffles for the cube from ½” material followed by a 7.5” x 6.5” right/left and a 6.5” x 6.5” top/bottom
Step 2: Sketch Your X Design
Create a design for the sides. I measured ½” from the edge and made a 1.5” X in the center.
Step 3: Cut Your Design
Cut a hole in each of the four triangles big enough for a jig saw to fit into. Cut the design out. Finally 45 degree chamfer all edges of the design.
Step 4: Clean Up
Hand chisel anything the router missed.
Step 5: Prepare Space for Acrylic
Rout ¼” from the edge of the back of the design for acrylic to sit.
Step 6: Fit Acrylic
Cut acrylic and check for a nice fit.
Step 7: Frost Your Acrylic
Sand both sides with 60 grit then 120 grit sand paper.
Step 8: Cut Your Front Baffle
Repeat the previous process for the front only this time rout out a 1.5” from the top and sides and 2” from the bottom to create a square opening.
Step 9: Insert Your Potentiometer
Mark potentiometer position and drill it out. Glue potentiometer in place.
Step 10: Prep the Speaker Rear
Drill holes in the rear for:
1. Power switch to shut off led’s
2. Power Plug
3. Aux in (only in rear with amp)
4. Speaker Jacks
5. Port
Step 11: Applying Your Port
Epoxy port in place, flush trim the port opening then do a 3/8” roundover on the baffle.
Step 12: Assembling Your Front Baffle
- Repeat the routing on the front piece but for the smaller square acrylic to fit.
- Cut a hole in the acrylic to fit the driver & attach the driver to the acrylic.
- Epoxy acrylic in place
- Seal all interior acrylic edges with hot glue
Step 13: Glue LED's Into Place
Place LED's surrounding the edges of the cutouts using hot glue.
Step 14: Wiring
- Connect the speaker to the speaker jacks.
- Take the end of an old 3.5mm cable, cut it, connect it to the amp and solder it to the leads on the 3.5 jack on the back of the speaker.
It is now time to power up the wiring. One of the positive leads will go into that switch and one will come from the amplifier. That's not to turn on the amplifier it's actually to turn on the LEDs. The other positive will actually go from the LED to that switch. The ground of both the amp board and the LED itself will connect to the ground of the power jack. If you need a more detailed description of how to wire it just check out the Wiring Schematic http://www.123toid.com/2017/12/the-sprite-custom-x-box-speakers.html
Step 15: Finishing Up
Glue the speaker together using the wood glue of your choice, hold the pieces in place with clamps while drying.
Sand and finish the speaker as you wish. For the Xbox custom feel, this speaker was painted a slate grey with an Xbox logo for the finishing touch.
Step 16: Parts List
Parts Used:
2 Speaker terminals of your choice.
2 Dayton ND90-8
1 Dayton Dta-2 Amp
1 12v strip of LED lights
2 Rocker switches (optional to shut off LED's when not in use)
2 Power Jacks
1 3.5mm Jack
2 20 ohm Audio Grade Resistors
2 0.9mh Inductors
2 Power Cords
1 2.1mm Jack
1 12v Power Supply 3a Power Supply
Step 17: Build Plans
Step 18: Build Video
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
