3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build Your Own Guitar
How to build your own guitar from scratch.
This instructable will help you learn how to customize your own guitar, starting with a body blank.
Step 1Shaping the Guitar
Shaping the Guitar
Shaping the Guitar is a difficult step. This will take a lot of time and will be challenging. You must obtain a body blank that can be bought at any wood specialty store. For my guitar, I just used a large piece of swamp ash, but you can also get different types of wood such as mohagony, but they will cost you anywhere from $55-$240. The first thing you should do is mark out where you are going to cut out on the body blank. I did this by tracing an old guitar onto the body blank. This may not be the correct size of a body, but you can always customize the pickguard to make it fit. To cut out the guitar body, I used a 1/4" blade on the bandsaw. To start, you should cut off any excess pieces of wood from the body blank that aren't needed. Now you must do a lot of relief cuts in the sharp turning areas of the cut. The best thing you can do is to take it easy and slow and slowly make your cuts.
7 comments
Mar 13, 2010. 10:42 PMdermord says:
Nice...and the Neck?
Jun 19, 2009. 6:24 AMlasersage says:
totally great that you're bothering to make your own guitar, but they way it reads sounds more like you're putting up with 2 pickups instead of 3, putting up with a tele bridge instead of a strat, and altering other things based on the shape of the scratch plate. Surely if you're going to the trouble of making your own nice solid body then you'd make it the shape and style you want and make a scratch plate to fit. Big sheets of scratch plate material (triple lam) are only like £10.
Jun 18, 2009. 11:47 AMBongmaster says:
hi it looks like u published this before it was complete ;)
Jun 19, 2009. 1:17 AMBongmaster says:
should have left the publishing til then XD it stores unpublished u know ;)
Jun 18, 2009. 12:11 PMKiteman says:
Agreed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:connorm
