3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build a Bamboo Bicycle
Step 4Tack frame togther
Tack frame togther
  • last photo ←
Now that you have heat treated the bamboo you need, cut, miter and tack the frame together.
You may choose to use a jig to hold everything in place. I did not use a jig so I am not going to go into that here. I don't know much about jigs so don't even ask.
I used the full size drawing and built directly off of that using spacers and standoffs to get everything in the right position.
Use a good half-round wood rasp to miter the joints.
Make sure that you use trigonometry to figure out the length of the chain stays and seat stays. What is drawn on the paper is a projected view.
Rough up the bamboo where the epoxy will go.
Rough up the metal too and stick it all together using 5 minute epoxy or your favorite glue.
Once it is all stuck together very gently put the wheels and fork in place and check alignment. If it looks good you are ready to move to move to the next step. If not
Note: The bamboo headset shown was not a good idea. I had to ream it out and insert a steel head tube because the headset cups did not seat properly in the bamboo and gave a scary wobble when turning corners! Start with a metal head tube and save yourself the hassle. The picture does show how rough your bamboo joint areas should be.
12 comments
Aug 15, 2010. 11:36 PMDandie says:
I think It is not a very good idea to build a bike frame of bamboo because It’s impossible to assure strong and safe joint sticks, especially in the headset, one of the most stressed pieces. I have seen more than once headset breakages and I can assure that the consequences for the drivers have been horribly serious, they hit the pavement with their faces,……. noses, jawbones, teeth smashed. I think this is not a matter to play with.
Jul 14, 2010. 11:37 PMjentran says:
For the headset, perhaps you could cut one so that there are nodes at either end to increase stiffness. There are more nodes located at the bottom of a bamboo culm than at the top. I'm not sure how thick the walls of the headset you tried was, that could help too. Some other people sprayed expanding form successfully to increase stiffness to the seat tube.
Jan 4, 2009. 8:42 AMNkevin90 says:
Okay, hopefully the last question; I really messed up on my headtube angle (but I couldn't help but laugh at it), so how would one go about taking all that crap off? I read up about sodium hydroxide or soaking stuff in acetone, but I'm not sure how great that either'd be for the bamboo itself. Oh right, and I used a steel tube by the way.
Mar 23, 2010. 3:29 AMartodoyo says:
very nice, its a handy craftman's work.
I've been working with bamboo for last 5 years.  You may try this bamboo species, its very "rugged", you can bend and shape it as you like.
http://www.axelhandicraft.com
Feb 11, 2010. 5:30 PMsnotty says:
Maybe try carefully chopping off the lashing with an angle grinder.
Sep 19, 2009. 12:36 AMbikefridaywalter says:
that DOES look good. should have extended the seatstays to the top tube for the old GT Triple Triangle effect :D
Jun 25, 2009. 8:50 PMjerandemma says:
This project looks awesome! I just signed up because of this bike. Has anyone thought of using lugs to join the bamboo? It would look good if you could epoxy the bamboo to the lugs, and it would be strong. All quality vintage bikes are lugged for good reason. Any thoughts?
Sep 19, 2009. 12:41 AMbikefridaywalter says:
i'm curious about this too-- i'm gonna see if i can track down some carbon lugs like they use for ti/carbon frames. i'll let you know if i can find anything :D
Sep 20, 2009. 8:33 PMjerandemma says:
Sounds Great!
Sep 26, 2009. 6:04 PMmagicalnumber12 says:
i am toying with the idea of lugs as well. i think it would work well and have a cleaner look. this is a project of mine for the winter. i am thinking about useing kevlar or carbonfiber at the joints as well. here is a bunch of good links
http://www.bikelugs.com/
http://www.cycle-frames.com/bicycle-frame-tubing/home.php
http://www.framebuilding.com/index.htm
http://www.gaerlan.com/bikeparts/bike.html
Have fun
Sep 28, 2009. 9:29 AMbikefridaywalter says:
cool well life is busy so if you beat me to to the punch, make sure to post some pix!
Aug 23, 2009. 8:18 PMsantimo says:
first, I´m sorry for my English. Did you pick the bamboo pieces in order to match with the size of the short bottom bracket lugs(is that the word for the small tubes that come out from the bottom bracket, those that are connected with down and seat tubes and stays?) or did you fit them by other means, maybe its explained and i´m lost in translation thans from argentina
Jul 20, 2009. 4:46 PMCrazyCanuck01 says:
Like the idea and am on the way to building one. But I was thrown when you mentioned trigonometry. Since I was a Political Science Major (I know stop laughing, I dropped out anyway lol). Is the some way of figuring this stuff out other then trigonometry. Great and informative Instructable.
Aug 17, 2009. 3:32 PMxman says:
You can use a CAD program to do the math for you :P
Apr 23, 2009. 2:38 AMslice_rulz says:
i absolutely love this project and cant wait to try it out for myself. thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:ayasbek
