Step 5Epoxy it all together
I used epoxy from fiberglass Hawaii called Aluzine (it is a 2 to 1 epoxy specially formulated for surfboards and has some UV inhibitors in it). Why? Because I had a lot of it left over from a repair to my windsurfer.
I used two different kinds of hemp fibers. I used raw hemp fibers (or semi-processed) and hemp twine (drawn out - semi-twisted, comes on a spool). The raw hemp seems much stronger so I used that as the bulk of the joint and then used the twine to tighten up the lashings.
Mask the frame off carefully. Prepare all the joint areas (clean and dirt free, heavily sanded or rasped for an extra-rough surface).
The process is pretty messy and requires a lot of patience and finesse. Wear gloves and start small - small batches of epoxy and small amounts of lashing. I mixed up a small pot of epoxy and then dipped my fibers in it. I then wrapped it on the joint and followed that with a dry piece of twine. There was enough epoxy on the raw fibers to completely wet out the twine. Practice and you will get it.
I got my hemp from www.downbound.com
Of course you can use kevlar, carbon fiber or fiberglass.
5
comments
Add Comment
Add Comment
