How to Build a Bee Vacuum
1,211
16
Published
Introduction: How to Build a Bee Vacuum
About: Free to Cook is a web show that will help gluten free people cook easy, fun and delicious food at home. From School lunches to cooking the junk food you thought you couldn't have anymore we will teach you fr...
Using a bee vacuum makes collect wild hives easier and damages the bees less than brushing them into boxes.
You also collect of the bees, which leads to a better outcome.
Step 1: You'll Need a Larger Box to Be the Vacuum Chamber.
You'll need to add an inlet and a wired box to capture the bees.
Step 2: Mark and Drill the Hole for the Inlet.
Drill into the lid and screw together making a seal around the lid.
Step 3: Make a Stand Tall Enough for the Box to Reach the Lid.
Make sure there is enough space for an inlet for the vacuum at the bottom of the box.
Step 4: Measure and Drill the Vacuum Input Hole.
Attach a joint to the inside and outside of the box.
Step 5: For Pressure Control Add a Tap.
Opening the tap will lower the pressure and closing it will increst the pressure.
Step 6: Next, You'll Need a Vacuum Cleaner.
Attach to the input at the bottom of the box.
Finally, attach a hose to suck up the bees.
Step 7: Cut Off the Bottom of the Tin to Give the Bees More Room When They Enter.
Step 8: All That's Left to Do Is Put It to the Test!
Step 9:
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Water Contest
      Water Contest
    3 Discussions
    This is really cool. Now, are you THE Bush Bee Man?? : )
    Thanks for sharing. Im new to bee keeping, just got my first lot of honey 2 weeks ago. I got a swam out of a tree that fell over, your bee vacuum would of made it much easier. I was thinking I might make a special top and bottom for a bee super that I can hook up the vacuum cleaner to, then I wouldn't have to move them out of the box.
    gm280
    3 months ago
    I realize honey bees are a commodity. But me, and bees in general, don't mix. I've had my share of bee stings in my life time. And if I never ever get stung again, it won't spoil my day. Nice project to save those bees.
