Step 6Solder More Stuff
iImage Information
Now, solder the terminal strip into place. Then, solder in the traces to the strip. Note that the positive trace is routed over the negative trace next to it, so you will need to leave a little insulation on the positive trace to avoiding creating a short circuit. Then, solder the wall wart wires on, noting polarity. Clip all the long leads close to the solder joint with the side cutters. Finally, make all the solder bridges to connect the components to the traces. Take care with sensitive components like the diodes and the regulator. These are sensitive to heat.
Shall the heatsink be grounded or something?
