Introduction: How to Build a DIY Wooden Guitar Stand (Free Template!)
This DIY guitar stand is a perfect beginner build. You only need a few inexpensive tools, a jigsaw and a drill, to build this stand. I designed the stand to fit most electric guitars, acoustic guitars, and banjos, but you could print the template at a smaller size to work with ukuleles and violins.
Make sure to check out the build video above for more details!
Step 1: Gather Materials & Tools
Picture of Gather Materials & Tools
As I said, this is a pretty basic build tools-wise. The project can be built from one 2 foot long 1x12, as long as you layout the pieces correctly. The other materials I used are below.
DIY Guitar Stand Materials:
Tools Used On DIY Guitar Stand Project:
Step 2: (Optional) Engrave Quote Onto Guitar Stand Using CNC Router
Picture of (Optional) Engrave Quote Onto Guitar Stand Using CNC Router
I have access to some pretty cool tools, including a CNC, so I tricked out my stand by engraving one of my favorite quotes onto the sides of the stand. This is obviously completely optional.
Step 3: Attach Template Using Spray Adhesive
Picture of Attach Template Using Spray Adhesive
Next, I attached my template to one side of the stand using spray adhesive. You can download this template for free on my website here: https://craftedworkshop.com/build-diy-guitar-stand-rack-free-template/
One tip here: apply spray adhesive to the paper and to the wood, then let it dry for a few minutes before attaching them. Doing this will make the paper template a LOT easier to remove later.
Step 4: Cut Shape Using Bandsaw / Jigsaw & Drill Relief Hole for Router Bit
Picture of Cut Shape Using Bandsaw / Jigsaw & Drill Relief Hole for Router Bit
I cut one side of the stand to shape using my bandsaw, but you could definitely use a jigsaw for this. Follow the line as closely as you can, and take it slow so you get a clean cut.
I also drilled a hole in the side of the stand. This is kind of optional, the reason I drilled this is so the flush trim bit on my router (used on an upcoming step) can get into this tight corner. If you're just going to be cutting both halves out and skipping the router, you can skip this step too.
Step 5: Refine Guitar Stand Shape Using Oscillating Belt Sander
Picture of Refine Guitar Stand Shape Using Oscillating Belt Sander
Next, I refined the shape of the stand using my oscillating spindle sander. If you don't have one of these, you can just use sandpaper and files instead.
Step 6: Rough Cut Other Half of Stand & Flush Trim Using the Router
Picture of Rough Cut Other Half of Stand & Flush Trim Using the Router
To get the other half to size, I traced the first half onto the second half, rough cut the shape at my bandsaw, stuck the two halves together using double sided tape, then used a flush trim bit on my router to flush them up.
If you don't have a router, you could just cut the other half to final size, stick the pieces together, then use sandpaper and files to get them to the same size.
Step 7: (Optional) Fill Letters With Epoxy Resin
Picture of (Optional) Fill Letters With Epoxy Resin
Here's another optional step. I filled my engraved letters with ArtResin epoxy, just to make them pop a little.
Step 8: Install Hinge, Drill Holes for Cord & Roundover Edges
Picture of Install Hinge, Drill Holes for Cord & Roundover Edges
Next, I installed the hinge on the inside of the two halves of the stand. I used an 1 ½" brass hinge. Another tip: when using brass screws, they're going to want to strip out on you. I applied a little paste wax to help with that.
I also drilled the hole for the cord, which will set the width of the stand. You want the hole to go through both halves of the stand here. Just use whatever size drill bit so that you can thread your cord through.
I also rounded over all of the edges with an ⅛" radius roundover bit on my router. If you don't have a router, you can just do this with sandpaper.
Step 9: Apply Finish
Picture of Apply Finish
Next, I applied finish, Waterlox in my case. This stuff looks outstanding on Walnut (the type of wood I used).
Step 10: Install Felt Bumpers
Picture of Install Felt Bumpers
I added some peel-and-stick felt pads to the stand where the instrument will come into contact with it. You probably shouldn't use rubber pads here, since some rubbers can interact with nitrocellulose finishes on some instruments.
Step 11: Set Width Using Cord
Picture of Set Width Using Cord
The last step is to thread your cord through the holes and tie a knot on each end. This sets the width of the stand. This width will be determined based on your particular instrument.
Step 12: Enjoy Your Stand!
Picture of Enjoy Your Stand!
Hope you guys enjoyed this simple project. If you'd like to check out more of my stuff, browse some of my woodworking projects on my website, and also get subscribed to my YouTube channel while you're at it. Thanks!
lathan1 made it! (author)2017-08-16
Thanks for the guidance.
Too cheap to buy printer ink, I scrolled and traced from the comp screen. As a result, my sizes are slightly off. Still, the template's availability got me started which is what I needed.
This is a 3/4" walnut slab planed down to approx. 3/8". This wood waste was to eliminate severe chip out obtained while using a forstner bit in a hand-drill; bad choice. Brown rubber window used as the cushioning and a red shoe string -waiting for some time for good use- as the gap adjustment.
Thanks for getting me started.With several small hangups to overcome, overall a simple success. The challenges beat, are the reward.
craftedworkshop (author)lathan12017-08-17
Awesome work! Glad you came out with an awesome looking stand.
RB01_ett (author)2017-07-12
I liked your project a lot and wanted to get the "Free" template. I didn't appreciate the fact that you are requesting Credit Card info, Address, as well as Email in order to make a free purchase. Isn't email enough???? I'm sorry but to me it is very irresponsible for people to trust other people with such private information in this day and age. I will figure out my own template thank you. It is a nice project. Bob Burchett
craftedworkshop (author)RB01_ett2017-07-13
As it clearly states on the template page, you can leave your CC info and address blank, it's just a quirk of the SquareSpace checkout system that it shows those fields.
Neo457 (author)2017-03-06
How are this tetraeder stands called you use for waxing the guitar stand.
Dee18 (author)2017-02-13
I started making one and my idea was not going to work. I always wanted a wood one. Will try your template.
Glad you warned people and said..."You probably shouldn't use rubber pads here, since some rubbers can interact with nitrocellulose finishes on some instruments."
This is very important... on one of my guitars, the finish was slightly scared near the head stock from a store bought, yet well made wall hanger! Now, on all stands that I have, I put a piece of fabric or felt around all the rubber parts.
craftedworkshop (author)Dee182017-02-14
Thanks!
Cuemarie made it! (author)2017-02-13
Thanks for this! I've been wanting to make some stands for our ukeleles. I (amateur weekend project-fiend) made these using a jig saw and handheld detail sander; I used your plan as a guide but just hand-drew the shape on the wood based on the size of the ukelele. This was fun and just challenging enough! I will probably add rubber feet to them and may upgrade the yarn (what i had lying around) to some stronger rope. Thanks for the great instructions!
craftedworkshop (author)Cuemarie2017-02-14
Nice, that's awesome! Great job.
jackfinnerty221 (author)2017-02-07
is it possible to use smaller dimensions? (I have a ukulele and this looks like an incredible way to display it.)
Yup, as I said in the Instructable, you could just print the template from my site at a smaller scale and use it for a ukulele.
Adam Gabbert (author)2017-02-07
My father-in-law's been hinting at something like this. This things beautiful, and will serve as some awesome inspiration, as always.
Thanks Adam! Let me know if you decide to make it, it'd love to see it.
About This Instructable
12,194views
120favorites
License:
Bio: Weekly how-to project videos about #woodworking, metalworking, and more. #Maker. Created by Johnny Brooke.
More by craftedworkshop:DIY Floating Wall-Mounted Bike Rack (Free Template!)Walnut and Copper Cutting Board / Serving Board!5 Woodworking Tools for Beginners
Add instructable to:
