Visit my website! Access to more photos through Flickr and my Etsy store:
detravoid.com
Like my Facebook page:
facebook.com/DetravoidConcept
Here is a list of materials you will need for building your very own Mau5 head as well as some estimated prices:
1 13" Hamster Ball ($30 at your local Petsmart or Petco)
1 5" Hamster Ball ($5 ^same place)
3 sheets of white foam core ($6 Hobby Lobby)
1 Hardhat ($10 at Lowes)
2 3mm Foam sheets ($2 at Hobby Lobby)
1 Can of Loctite spray adhesive High Performance ($8 at Lowes)
1 Roll of Ductape ($4-5 any color at any store)
1 bag of zip ties, although you will only use 7 ($3 Lowes)
4 long screw rods (not sure on pricing here I got mine from spare hardware from IKEA) although you can purchase a long rod
from Lowes and cut that into 4 sections about 5-7 inches each)
1 Bag of plastic washers (I also got these from IKEA spare parts, but any washer will work, you will need several to create
space between the hardhat and the Hamster ball)
5 Wing nuts (Not sure on pricing for these, but you can purchase them at any hardware store, make sure they match the size of
your rods.
1 Round head bolt matching the thread size of the other hardware
1 Bottle of Gorilla Glue ($5-$10 depending on the size of the bottle, both quick dry and regular work well)
1 Yard of your main color stretch fabric, In my case I'm using red ($15 at Joann's)
1/2 Yard of secondary color, I'm using white for the eyes and mouth ($8 Joann's)
1 Wire basket ($2.50 from IKEA)
Optional: El Wire from Coolneon.com
Assembly Tools:
Dremel with cutting attachment (I realize mine is broken, just using it as reference) and drill bit (preferably the bit shown in picture)
Glue Gun
Scissors
Utility knife
Screwdriver with Phillips bit
sharpie
pliers
needle and thread
Remove these ads by
Signing UpStep 1Drawing out the mouth
1 - Looking at the first picture, I aligned the top cap EXACTLY as shown, with the handles facing straight and center with the space between the screws holding the hamster ball together. Now apply hot glue to this from the inside to ensure it stays in place as shown in the second picture.
2 - I then applied duct tape to the spaces between the hamster ball so that it keeps it's integrity once I begin to cut into it and over the gaps for the screws. Make sure to allow space to remove the screws as shown in the fourth picture.
3 - Getting a bit ahead, I cut two 1 inch strips of the foam to use as a measure to draw out the mouth. As shown in picture 5 The front center of the Mau5 head is marked. The bottom lip starts 1 inch from the bottom front (remove and discard the bottom cap for the hamster ball)
4 - Mark the sides where the corners of the mouth will be as shown in picture 6. The mark will be made just before the 3rd screw from the front center of the Mau5 head on either side as seen in picture 10. I then used the strips of foam as shown to create a guide to draw out the bottom of the mouth.
5 - As shown in pictures 7 and 8, begin to draw out the line for the bottom of the mouth.
6 - Now measure 1 inch from the equator of head upward and run the strip of foam as shown to draw out the line for the top of the mouth as shown in picture 9.
13
comments
Add Comment
Darkmantis (author)
says:
Darkmantis (author)
says:
Darkmantis (author)
says:
Darkmantis (author)
says:
Darkmantis (author)
says:
Darkmantis (author)
says:
Add Comment
