1. Lay down two pieces A parallel with each other. 2. Screw four pieces B to the inside of A. Use a level to make the base level. 3. Attach piece C ...
1. Attach pieces F to D. Use tri square to make beams perpendicular to floor. 2. Assemble pieces G and H to the corner beams (pieces F). 3. Center p...
1. Assemble pieces L and M together to form a triangle. 2. The 30 degree angles should be placed against pieces L. 3. Pieces L should come together ...
1. Attach face plate (Q) to front wall (P), pieces A, and piece B. Use level to make the face plate level accross the bottom of the front of the dog h...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
