How to Build a Hermit Crab (or other small critter) Cage by samfelis
Featured
This instructable will provide you with the details on how to build a hermit crab cage. If you're not a fan of hermit crabs, you could use it for hamsters. Or lizards. Or mice. Or...well, you get the idea.
The kids decided they wanted to get hermit crabs this summer, but when I saw the price of new cages at the boardwalk sea shell shops, I knew I could make them a larger cage much cheaper.
Kiteman and RedThreadsOfFate added some words of advice on keeping hermit crabs and I think it should be pointed out as well. Hermit crabs require an environment with high humidity (70-80%). Although this mesh cage will not provide that environment, it will serve as temporary housing until a more suitable, permanent home can be found.
If you're interested in learning more about caring for your hermit crabs, take a look at one of the following sites:
http://hermit-crabs.com/
http://www.hermitcrabassociation.com/
http://www.crabstreetjournal.com/
Step 1: Ingredients
Here's what you'll need to build one like I did. If you want a bigger (or smaller) cage, adjust the size of your dimensions as necessary.
First and foremost, you need a plan. The old adage of "fail to plan, plan to fail" will bite you otherwise. Sketch out your cage from a couple of angles, labeling the pieces that you'll need to build. Be sure to use sizes that are mass produced and easily available at your local lumber yard, otherwise you'll be back at the drawing board.
The measurements below are based on standard size wood stock (but real measurements). For instance, the board that makes up the floor and back was sold as 1" x 12" even though it really measures 3/4" x 11 1/4". I don't know why that is...maybe it's a vast wood industry conspiracy to confuse us or something.
Here's the list of materials (and the dimensions) for the cage I made:
Materials
3/8" x 1 1/2" x 18" (4) -- wood trim (2 front, 2 top)
3/8" x 1 1/2" x 12" (2) -- wood trim (2 top sides)
3/8" x 1 1/2" x 10 3/4 (4) -- wood trim (sides)
3/4" x 1 1/2" x 10" (4) -- wood vertical supports
3/4" x 11 1/4" x 18" (2) -- wood floor, back
10" x 18" (2) - wire mesh - top, front
10" x 8 3/4 (2) - wire mesh - sides
2" Hinges (2) (comes w/ screws)
Hook and Eye (1 each)
6" length of chain (need a 3/4" screw)
*the wire mesh was sold in a roll 72" long and 24" wide. This worked out perfectly as I was able to get the four pieces I needed cut with a minimum of waste (see the right part of the plan for a sketch of the four pieces of mesh I would need).
Tools
jig saw (a table saw could be used instead)
miter saw
drill/bits
wood glue
staple gun (loaded with 1/4" staples)
sandpaper (fine grit)
wire snips
corner frame clamp (optional, but comes in handy when gluing the top frame)
primer
paint
sally300 says: Sep 14, 2011. 11:36 AM
do the hermite crabs get very big
RedThreadsofFate says: Aug 20, 2009. 4:52 PM
As Kiteman said above, this type of cage isnt suitable for a hermit crab. Hermit crabs need at least 70% humidity (Max 82% humidity) in their environment to breathe. they have modified gills, which wont allow them to breathe completely submerged, but requires them to have high humidity to breathe. they also require warm environments. (between 70-80 degrees Fahrenheit) in order to stay active.
I'm not an expert with other animals, but please try and research a bit more on hermit crabs. they arent throw-away pets and they actually live very long lives when cared for properly, even past thirty years of age!
This may be a good project for other animals, or just to spend the afternoon on, but not for hermit crabs.
for anyone interested in hermit crab care, please look to sites such as
would it be a problem if i asked you to put a disclaimer that this should only be a temporary home until a proper one can be obtained...?
samfelis (author) says: Aug 20, 2009. 6:27 PM
Thanks for the detailed information (as well as the specific sites). I'll go ahead and add this to the introductory step.
sally300 says: Sep 14, 2011. 9:00 AM
how many hrmite crabs can you put in there
crazydaizy says: Mar 24, 2010. 6:40 AM
 It's fine for hermies to travel home in, but not on a 10 hour road trip. In other words, you could bring him to the other side of the state and back (careful not to bang him around) and he'd be a bit shellshocked (no pun intended) but still OK.
Hermit crabs aren't meant to be toted around like dogs.
You can go to http://www.hermitcrabaddiction.net/forum to get more information.
sally300 says: Sep 12, 2011. 6:13 PM
is that known as an all time hermite crab habatate or is it just for a few days cause i dont understand it
samfelis (author) says: Sep 13, 2011. 5:37 AM
It's probably more suited to a temporary home. I modeled it after the cages I saw at the beach (where the kids got them), but didn't take into consideration that they (the hermies) don't stay in there very long.
That being said, our hermies lived over three years before they died (with a 2-3x a week spritzing in an indoor environment and a weekly bath in the sink), so....YMMV.
Mauigerbil says: Aug 18, 2011. 10:19 AM
Cool! This could be used to house baby gerbils or mice for awhile before they are too big for it.
crossless says: Nov 30, 2009. 2:00 AM
 I would use that size only for travelling cage . for hamsters etc..
komecake says: Oct 22, 2009. 10:48 PM
  I pretty much built the same thing earlier this year, but much taller and I used an old dresser drawer as a base. I was looking for instructions on how to build a base from scratch for when I make an "updated" version, so thanks for the instructions. This looks much cleaner than my cage as well as I wrapped the wire on the outside of the cage because I was afraid of my rats getting cut on the wire. I have a solution for that though.
Kiteman says: Aug 20, 2009. 1:26 PM
Unless you live in an extremely humid (tropical, in fact), mesh cages are not suitable for hermit crabs - they should be housed in glass or plastic tanks with lids. Apart from that, it's a nice project.
Wolfbird says: Oct 8, 2009. 3:16 PM
Agreed (on the general subject of "wrong cage type").
For my own two cents, I'd vote for this being renamed, even if it's just to "small animal cage". It's a pretty cool project, but it does smack too much of encouraging people to get special-needs pets before they're ready to take care of them.
That said, looks spiffy for some pets who don't require anything more complicated than open-air environments.
samfelis (author) says: Aug 20, 2009. 6:25 PM
Thanks for the kudos, as well as the tip on humidity levels. (I had heard that elsewhere, which is why I added "or other small critter" as well as the link on the last step.) So far the hermies love it. The kids spray them every morning and night and give them baths a few times a week (in the kitchen sink, no less!).
RedThreadsofFate says: Aug 20, 2009. 7:33 PM
try to keep baths to once a week, or better once every two weeks. it can stress them out, especially in a new environment. and hermies love to climb! so make sute they have lots of non-metal toys/objects (metal toys rust, which can harm them). also, as a side note, many tap water and bottled water contains chlorate and chlorine, which can burn the gills of your hermit crab. you'll need some type of water conditioner (like the freshwater aquarium stuff) to make sure your water is safe for them. chlorine will evaporate, but chlorate wont.
samfelis (author) says: Aug 20, 2009. 7:55 PM
We do condition the water before we bathe them and the spray bottle water has been conditioned as well. We have fish as well so are well versed in having to condition the water.
RedThreadsofFate says: Aug 20, 2009. 8:12 PM
fantastic! i hate to think how many poor crabbies have died because someone burned their gills with tap water...like breathing bleach! well, this is a good project, and i think if someone lowered the proportions, and made the mesh smaller, it could also be a bug habitat!
Daethian says: Aug 26, 2009. 7:28 AM
Thanks for adding the disclaimer about this not being a suitable permanent home. Thanks to the others for linking to us at CSJ! w00t! You could still build a very cool home habitat with plexiglass. I've seen that done numerous times. OR watch Craigslist and yardsales for FREE tanks, doesn't even get cheaper than that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
