3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build a Magnetic Levitating Top
Nope, no Photoshop and no fishing line were used to make this picture, just 100% pure physics and some patience. This instructable explains how you can build your own top hovering in the air like a UFO.
Step 1Video Overview
Video Overview
Some steps of this instructable are difficult to explain with plain text or even show with static pictures, so I encourage you to also check this video illustrating the build and tuning process. Sometimes it is better to see once than read a hundred times.
48 comments
1-40 of 48next »
Aug 8, 2011. 8:26 AMAltonB says:
Excellent instructable. I have been working on building a mechanical based clock utilizing magnetic energy in order to extend run times, as well as, general experiments. There is a lot more to magnetic energy than conventional science would have one believe. For every law of physics there IS a loophole -(remember - conventional science at one time said human flight was imppossible)- it simply takes a lot of time, effort, and energy to find it. I appreciate your very thourough explanation of the process you use and excellent instructions. Your command of the english language is very good. Keep up the good work and I intend to check out your other stuff.
Alton B.
Aug 25, 2011. 9:32 AMTinmanmike says:
A good source of strong donut magnets is a broken microwave. They all have two good magnets in them. Wrapping electrical tape around them makes them chip resistant and easier on your fingers.
Jan 15, 2012. 9:18 AMblinkyblinky says:
So, if the temperature dropped or the humidity changed it would fall?
Jan 15, 2012. 11:20 AMTrooper555 says:
Dude this is great! hope you do more.
Aug 1, 2011. 3:46 PMaharner1 says:
in soviet russia magnet repels you!
lol awesome video
Dec 9, 2011. 6:31 PMpaperairplanecreator says:
Awesome accent.
Oct 9, 2011. 3:13 AMmondeluz says:
this system is used in alien space ships XD
Aug 6, 2011. 1:53 AMvdhamodharan says:
for how long will this spin??
Aug 5, 2011. 5:45 AMchaitanyak says:
genius!
Aug 2, 2011. 2:23 AMdoomsdayltd says:
i see what your doing, the magnetic field is holding the magnetic top in place. very simple thing with magnets but very neat.
Aug 2, 2011. 10:43 AMcwinget says:
I've seen this at a magic shop; I guess I know how he was doing it now :B
I like your accent too, would you mind telling me your native language?
Jul 31, 2011. 12:58 PMkea says:
Some years ago Ispent $40 on 1 of theese gadgets. Nobody in the family could get it to work. Not 1 of us could find the sweet spot.
It looks like it could be a great project to do.
Good work.
Cheers KIWI
Aug 2, 2011. 1:45 AMt.rohner says:
I think those gadgets are different. If they have a power connection, they are made with electro-magnets and some sort of sensor.(light-barrier most of the time) With this, you can levitate any ferromagnetic thing with the right weight and size. We built one from scratch with all-analog circuits some 30 years ago. In order to reduce the current through the electro magnets, we added permanent magnets. With that, we hung a little globe-pencil-sharpener out in the air. The magnets were about 1.5 inches above the globe.
Aug 2, 2011. 12:19 PMkea says:
Thanks for your thoughts guys. I gave to a friend who could not get it work & he gave it away I think.
Cheers. Kea
Jul 31, 2011. 10:57 AMdokcal says:
Awesome! One of the best Instructables I've seen!
I have a Super Levitron with all the accessories--got it to hover for several hours once!--but I always wondered what the configuration of magnets in the base was. Much simpler than I thought!
One question: They used to sell a "Perpetuator" that sat under the main magnet and kept the top spinning longer and higher. It was powered by a wall transformer and didn't seem to have any moving parts.
I'm sure it must have been a very simple device, but I can't imagine what it was. I would think any variation in the magnetic field (rotating magnets or coils switching on and off) would tend to DEstabilize the top! A single big coil would certainly make it hover higher, but I don't see how it would make the top spin longer.
Any thoughts on what it might be?
Jul 31, 2011. 8:47 PMdokcal says:
Ha ha! No worries! I think your command of English outstrips my command of physics! ;>)
I had to look up "precession," but your theory certainly makes sense to me.
Thanks!
Jul 31, 2011. 8:21 AMjtharkness says:
Love it! Well explained also.
I wonder how long a well balanced top would stay spinning and levitated in a vacuum. Of course creating the vacuum after manually spinning the top would be an instructible all its own.
Jul 31, 2011. 11:23 AMkimvellore says:
I was wondering after getting this to work if you spin the bottom magnet will the top magnet keep levitating for a longer time?
Jul 31, 2011. 6:15 PMlordmarx says:
wow its cool. if it is possible to make it spin forever you can just add a coil to it to make a generator. a generator powered by magnets. no other source. it will be very good source of energy.
Jul 31, 2011. 8:04 AMericCycles says:
Do stacked magnets generate a stronger magnetic field than one magnet? If not, could you replace the second magnet with any magnetically neutral spacer, like a piece of styrofoam or wood?
Jul 31, 2011. 4:29 PMGlenn Burrow says:
Sorry, mikhalchuk, But that is not correct. The sides that contact each other cancel out. You end up with a magnet of the same strength but double the size.
Jul 31, 2011. 4:31 PMGlenn Burrow says:
If you were to force them against each other, that effect may be attained. But not if you allow them to go the direction they want.
Aug 9, 2011. 6:22 PMGlenn Burrow says:
Letting the magnets go the way they want when stacking them makes the fields larger because of overlap but not stronger. but if put in a direction against their "wish" they have a stronger field.
Jul 31, 2011. 8:39 PMTreknology says:
Stacking magnets is not always a solution. If you chain them long enough they will self-node, and fall apart at those node points.
The only real problem with this project is that the top is balanced on a point of UNSTABLE EQUILIBRIUM, i.e., the forces that are balanced are all trying to pull the top out of the "sweet spot" whereas a pendulum is and example of STABLE equilibrium because the combined forces keep drawing it back to the point of stability.
It looks like fun to try out, but I don't want to destroy any of the decent speakers that I have...
Nov 17, 2011. 3:25 AMtboswell says:
do you have a picture/thread for this "pendulum"? I've been working on one and would be interested to see what other results look like...
cheers, tom
Jul 31, 2011. 1:39 PMmuiftikhar says:
it is a fact that i have tried several time to levitate by using magnets, but really this is an tough one to perform because of that point where all forces are acting equally :(
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:mikhalchuk(RTFMS.com : mods, hacks, rtfms)
