How to Build a Norwegian Bird Condo From a 2X4
8,622
152
7
Published
Introduction: How to Build a Norwegian Bird Condo From a 2X4
Ok so maybe this is just a bird house, but it reminded me of an Instagram photo a friend took took of houses in Norway - the point is - this tutorial will show you how to make it entirely from a single 2x4!
Step 1: Gather Materials
What you'll need:
  • Safety gear
  • Tape Measure
  • Pencil
  • 96" 2x4
  • Table Saw
  • Brad Nails
  • Hammer or staple gun (staple gun recommended)
Step 2: Square Up Your 2x4
Set your table say to about 3/16" and lob off those corners,
The piece you end up with will be about 3" wide x 1-1/2"
Step 3: Make Four (4) 1/4" X 3" X 96" Pieces
This is the 'stock' that the entire bird house will be made out of.
Results may very depending on the kerf of your blade but I was able to get exactly four (4) boards
Step 4: Cut Your Roof Pieces (1/4" X 3" X 4") With Bevel
One of the first cuts you'll want to make is a 45 degree bevel down the length of one of your boards.
You want to make this cut on a long board for safety reasons but you actually don't need to do it for an entire 96" you only need about 26" of roof boards so if you want to just make this bevel on that length of board you can.
Now cross cut this board with the bevel in it into six (6) 4" long pieces
Step 5: Make Twelve (12) 1/4" X 3" X 7-12" Pieces
These are the front and sides of your bird houses. At 7-1/2" there're going to be a little longer than you need them to be but you'll trim them up later.
Each house has four (4) sides and there are three (3) houses so you need twelve (12) of this piece. You should be able to make these from a single 96" board. Once these are cut set them aside.
Step 6: Make Six (6) 1/4" X 3" X 7" Pieces (with Point)
Set your cross cut guide to 45 degrees and put a point on (6) of your 7-1/2" boards you just made.
These are the fronts and backs of your 3 houses.
When you're done set the cross cut guide back to 90 and trim your pieces to to 7" long
Step 7: Put a 45 Degree Bevel on the Remaining Six (6) Pieces
These are the right and left sides of your 3 houses
Step 8: Nail the Walls of Your House Together
Unless your a robot, some pieces will fit together better than others, experiment with the parts of your 3 houses until you find a combination of parts that seems to work for all three, then nail the 4 walls together.
There isn't a pictures of this step but if you've been keeping track of measurements, the sides of your house are way longer than the front/back of your house. After its nailed together you want to trim everything square on the table saw. Because of the arrangement of your pieces there shouldn't be any nails in the way of the cut but make sure the're aren't before trimming.
Step 9: Attach the Roof
If your roof halves don't line up (as shown) you can trim them even on the table saw like you trimmed the bottom of the houses.
Step 10: Make Three (3) Base Plates 1/4 X 3" X 2.5"
Now the houses need a floor or a base plate,
Cut three (3) 1/4 x 3" x 2.5" pieces from the remaining wood and nail them in
Step 11: Join the Condos, Drill Holes, Sand, Stain
Ok this is 4 steps but they're easy ones everyone know how to do
You should have some 1/4" x 3" boards left - how you join the houses is up to you. My houses weren't exactly the same height when I was finished so I put them at an angle to hide that. You can make them go straight across if you'd like or any other arrangement you can think of.
I drilled the hole (1-1/4") after the houses were joined together but you could also do it before
Sanding and staining are the last sub-steps. If I had to do this again I would have painted these different colors to match the colorful houses in the picture I describes on the first step.
Step 12: Attach to Tree, List Norwegian Bird Condo on Real Estate Website
You can attach you Norwegian bird condo directly to a tree through one of the 'doors'
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    7 Discussions
    These look really good, but it would be good if you could easily remove the roofs - in between uses, you should clean out old nest materials to stop future tenants getting infections or parasites from previous birds or from decaying nest material.
    why not incorporate a hinge on the roof using an old inner tube from a car or bike to keep it water proff
    Hi,
    A great project that will bring hours and hours of pleasure to all that see it,
    Just as an extra little bit of help to the birds "i'd use a dowel (rounded peice of wood) just under the entrance hole so the birds feeding thier young have a landing place and the the young when ready for taking those first steps into flight have a place to take off from,
    But this is a really good project, Well done.
