Introduction: How to Build a Phone Charger in 2 Minutes
Picture of How to Build a Phone Charger in 2 Minutes
in this instructable, you will learn how to build a phone charger in no-time and almost no tools.
all you need is:
scissors
2 X 3V coin battery
old (working) phone charging cable
some kind of tape
Step 1:
Picture of
first, about the charging cable, you need to cut it after the USB connection which will expose 4 wires. you need to cut the two that are responsible for the data transportation leaving only the black/blue and the red wire. then tape the black wire to the rough side of one battery,
Step 2:
Picture of
now tape the smooth side of the second battery to the red wire of the cable
Step 3: You Are Done!
Picture of You Are Done!
now tape the two batteries together, with their empty sides facing each other - rough side to smooth side. and that's it!
version 2.0 coming soon
DIY Hacks and How Tos (author)2017-12-09
Is this really able to charge the phone? It seems like the phone battery would have a higher capacity than the coin cells.
you are semi-right. it does only have a disappointing power of about 450mah but for checking your inbox or to call sombody once a while it does a pretty good job
About This Instructable
61views
0favorites
License:
More by adaros1243:How to Build a Phone Charger in 2 Minutes
Add instructable to:
