Step 15Align brackets and pre-drill holes
Flip the picture and frame over, and set them on some sort of padded risers. I've used towel-covered milk crates. Make sure you're not going to damage the surface of the painting, then carefully re-align your picture within the frame according to your previous measurements. Position the L-brackets so the ends sit over the frame without protruding, and the angled portion sits over the stretcher.
Chechen and other dense hardwoods definitely need to be predrilled to avoid splitting, and it certainly won't hurt the softer wood of the stretcher. Select a drill bit slightly smaller than the screw you're planning to use: the bit should be the width of the screw minus the threads, since the threads still need to catch in the wood.
We'll predrill and screw the frame first, then move on to the stretcher; this will make sure everything fits nicely without shifting. As you drill, don't push too hard, and make sure to back up frequently to break and remove chips that will otherwise clog your drill bit. Also make sure you're drilling perpendicular to the wood- any additional torque on the drill bit can cause it to snap when you're working with an extremely hard wood.
I'm stressing this because Chechen turns out to be really hard- I broke off a drill bit and a screw when attaching the L-brackets.
Add Comment
