3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build a Picture Frame
Step 7Prepare for biscuit cutting
I decided to use a biscuit joiner to make my corner joints. It may not be the best technique for such small wood, but this technique makes strong joints. I was concerned about creating sufficiently strong and rigid joints, and wanted to practice using my new biscuit joiner.
To prepare for biscuit cutting, first identify the size biscuit you'll use and where it will be located. The hole you cut will be slightly larger than the biscuit itself, so make sure you position the biscuit cut appropriately. Sketch in the location of the biscuit cuts, as they're another one of those points of no return.
Clamp your boards down firmly to your work surface, positioning them for proper attack by the biscuit joiner. Mine cuts horizontally, so I clamped the wood down as shown below. Since the pieces of wood are small I clamped two together to help support/stabilize the biscuit cutter, oriented such that I could cut the outside edge of both pieces.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
413
Author:canida
I've been posting Instructables since the site's inception, and now run Community and Marketing. Follow me for food and more!
