Introduction: How to Build a Plate Rack
Build a mounted storage shelf to corral your crockery.
If you're looking for a way to dramatically boost the charm and functionality of your kitchen, consider adding an open plate rack. It mounts to the wall, leaving counters uncluttered, and gets your dishes out in the open—easy to grab and hard not to admire.
The fine example at right features shapely sides and Shaker pegs to hang cups or towels. To build it, you'll need a few pieces of poplar or equally solid lumber for the sides and shelves, a piece of beadboard for the back, and hardwood dowels. It mounts with a French cleat, which you can make from wood or purchase in metal.
Alternatively, if detail work with dowels doesn't sound like your cup of tea, there are any number of options you can buy instead, ranging from mass-produced models to handcrafted marvels. No matter what, you'll feel good giving your dishes a proper place to shine.
Download and print a cut list for building a plate rack.
Step 1: Learn the Anatomy and Go to the Store
Fit the design to your dishes by altering the depth of the sides or the space between shelves.
CUT LIST
Download a printable cut list here.
Side panels
1x12 poplar: two @ 32 inches
Shelves
1x poplar: one @ 4 by 20 inches
1x poplar: one @ 7 by 20 inches
Back panel
½-inch beadboard: one @ 32 by 20 inches
Dish rack
5/4 poplar top rail: one @ 1½ by 20 inches with a 1-inch-wide 45-degree beveled face ripped along one corner
5/4 poplar front rail: one @ 1 by 20 inches with a ½-inch-wide 45-degree beveled face ripped along one corner
5/4 poplar back rail: one @ 3¼ by 20 inches
Diagonal dowels: nine @ 13 inches
Horizontal dowels: nine @ 7 inches
OR...
Consider a DIY Kit to Make This and Other Kitchen-Storage Upgrades
CUT LIST
Side panels
Shelves
Back panel
Dish rack
OR...
Step 2: Cut the Pieces
To lay out the curved sides, first mark the back edge of a blank at each shelf location: 5, 18, and 29 inches from the bottom. Add ¾ inch to the depth of each shelf, then measure and mark that distance from the back edge at each shelf location. Tack a brad at each mark, and tack one near the top and bottom edges, inset ¾ inch from the back. Next, bow a thin batten between each pair of brads and use it to trace four shallow arcs. Gang the two side blanks and cut along the lines with a jigsaw.
RELATED: 10 Easy Kitchen Cabinet Upgrades You Can Finish in a Weekend
Step 3: Drill the Dowel Holes
For the horizontal dowels, drill ½-inch-deep holes every 2 inches in the front and back rails. For the diagonals, offset the holes in the beveled faces of the top and front rails ¼inch from the first set.
Step 4: Assemble the Rack
Glue the short dowels into the back rail, then glue the front rail onto their free ends. Glue the diagonal dowels into the beveled faces of the front and top rails.
More ideas from thisoldhouse.com
How to Build a Window Seat with Stock Cabinets
Refinish Hardwood Floors without Sanding Down to Bare Wood
How to Paint Kitchen Cabinets
How to Build a Small Deck
Build a Charming Jelly Cupboard
