Step 7Grind and fill holes
Next, let the slab dry and mix up some pure cement with some pure acrylic fortifier, until it is smooth and about the consistency of a shake. If it doesn't pour easily it is too thick. I found doing it in three stages worked best, as the stuff likes to shrink as it dries. spread one coat evenly over the surface, working it into the holes and voids. let it dry a bit until it has set up pretty well, then scrape all of the extra off of the surface. now repeat this process, filling in any holes you missed or holes that didnt fill all the way. Lastly repeat again, but do not scape off the extra. leave a layer of the mix on the surface in case it shrinks more than expected. let this cure overnight,then grind it off with the roughest polishing pad, probably 50 or 100 grit. inspect for any holes that didn't take the patch material well, and repeat the process if necessary. Surface should feel smooth, and the filled holes may be darker.
4
comments
Add Comment
CapnChkn
says:
hivoltage (author)
says:
Add Comment
