Step 7Install the bulkhead fitting
Insert the threaded end of the bulkhead fitting through the outside of the barrel. (The thick rubber washer should be on the outside of the barrel.)
Using a pair of long handle pliers and an assistant, place the thin, hard plastic washer onto the bulkhead fitting followed by the large nut. Tighten securely. (Note: The word tighten on the large nut faces the inside of the barrel.) These are reverse-threaded bulkhead fittings. Turn counter-clockwise to tighten.
comments
Add Comment
Add Comment
