Step 8Install a threaded adapter and hose connection
The threaded adapter has one end with closely spaced threads and one end with wide threads. Wrap several layers of Teflon tape around the narrowly spaced threads.
Insert the threaded adapter into the bulkhead fitting. (The teflon taped, narrow threads go into the bulkhead fitting.) You can tighten this with an open end wrench or a pair of pliers, if necessary.
Thread the garden hose spigot onto the adapter with just enough pressure so that the washer seats on the adapter. Do not over-tighten as this will cause damage to the rubber washer.
This hose connection has a much larger hols than most and will give the highest water pressure possible from a rain barrel.
Add Comment
