How to Build a Robot - The BeetleBot v2 ( Revisited )
Step 1The BeetleBot v2 ( Revisited ) - The component list
This is what you will need to build this robot.
Items for the robot:
2 x 1,5V motors
2 x SPDT ( single pole double throw ) switches with a metal lever
2 x AA or AAA battery
2 x Terminal connector ( see picture )
1 x AA or AAA battery holder
1 x Plastic or wooden pearl ( Spherical bead )
1 x 1 inch x 3 inch piece of metal or aluminum
1 x Toggle switch for the on/off switchs
Paper clips big and small
2 feets of wires around 22/24 Gauge size
Heat shrink that will fit over the motor shaft and some that will fit over the terminal connector
Electric tape and masking tape
Items for the body shell :
Round plastic lid to make the shell of the robot
Some spray can paint, the colour you want.
Clear varnish
Autobody filler putty or epoxy glue
2 x Small magnets to attach shell to body.
You need some 1,5Volts motor, not 3V or no event 12V!!
Each motors are powered by a single AA battery. You will drain your battery if you use a bigger motor. You can find them in toys or even at your local dollarrama, in little car, fans, etc! ( beware, they might really suck you battery down )
the recommended tools for this project:
1 x safety glasses!!
1 x soldering iron
1 x glue gun
1 x wire strippers
1 x side cutter
1 x scissors, knife, x-acto, etc
I recommend you to take the time to read this entire instructable before starting. In every page I have added a lot of pictures, so don't forget to look.
37 comments
Sep 16, 2009. 8:05 PMCaassh says:
Aug 9, 2010. 8:10 PMlinkz601 says:
they work.
Jul 18, 2010. 11:29 PMr_carron says:
also what size are the terminal connectors because the place i am shopping at has these . which should i choose? http://www.dse.co.nz/dse.shop/4c43f01f01e615be273fc0a87f3b06af/Product/View/H3203 http://www.dse.co.nz/dse.shop/4c43f01f01e615be273fc0a87f3b06af/Product/View/H3200 http://www.dse.co.nz/dse.shop/4c43f01f01e615be273fc0a87f3b06af/Product/View/H3201
Jul 18, 2010. 11:23 PMr_carron says:
hello i was wondering if this motor will work http://www.dse.co.nz/dse.shop/4c43f01f01e615be273fc0a87f3b06af/Product/View/P9003 is the shape ok? please reply
Dec 30, 2009. 1:09 PMevan_jeffries says:
 is a soldering GUN okay?
Oct 24, 2009. 8:43 PMr_carron says:
 i was also wondering if i could get these terminal connectors?
http://www.dse.co.nz/dse.shop/4ae3c6f9026e8842273fc0a87f3b0729/Product/View/H3217
Oct 24, 2009. 8:16 PMr_carron says:
 hey im a beginner at this and i chose the beetlebot to be my first robot which i will stat making very soon. I bought 2 micro mini SPDT switches and they are 240 VAC , 1.5 A .  are they the right ones? will they work?
amazin work btw =]
Sep 17, 2009. 4:31 PMCaassh says:
Thanks
Sep 16, 2009. 8:17 PMCaassh says:
i meant i found the same SPDT switch but i still need the on/off switch help please.. thanks
Sep 16, 2009. 6:12 PMCaassh says:
where did you buy the terminal connectors?
Also can i use any of these terminal connectors?
I'm making a beetlebot for a school project o.o
-http://www.radioshack.com/product/index.jsp?productId=2104019
-http://www.radioshack.com/product/index.jsp?productId=2104091
lol says female >.>
Sep 16, 2009. 7:29 PMCaassh says:
nvm i found the exact saem switch you have :)
http://www.allelectronics.com/make-a-store/item/SMS-220/SPDT-MINI-SNAP-ACTION-SWITCH-W/-LEVER/-/1.html
for anyone who needs it
Aug 11, 2009. 10:57 AMrancher52395 says:
how big would you say the robot is?
Jul 28, 2009. 6:47 PMrancher52395 says:
what is the estimated cost if you don't have any of the items for the robot? just the robot parts, not the shell or tools. thank you!
Jul 28, 2009. 7:12 PMrancher52395 says:
one more question- what should the circumference be for the heat shrinks? how big of round are the terminal connectors and the motor shaft? Thank you so much!
Aug 6, 2009. 12:00 PMrancher52395 says:
do the terminal connectors have to look like the ones in your picture? or can the have two prongs on the end?
http://www.radioshack.com/product/index.jsp?productId=2103306
or
http://www.radioshack.com/product/index.jsp?productId=2103309
can they look like either of these?
Aug 6, 2009. 12:32 PMrancher52395 says:
ah, i c how yours are...where did you get yours? i can't find ones like that on radioshack.com...please help me!
Aug 6, 2009. 1:57 PMrancher52395 says:
okay I found them, whew!
Jul 28, 2009. 7:02 PMrancher52395 says:
and where can you find the spdt switch?
Jul 28, 2009. 7:13 PMrancher52395 says:
never mind about the switch, I found it
Jun 21, 2009. 12:13 PMjuggler4real says:
where can i get a spdt switch for low price or free
Aug 6, 2009. 12:47 PMrancher52395 says:
radioshack.com has some for about 2 dollars i think
Aug 4, 2009. 11:47 AMrainger says:
Just like Robomaniac mentioned about finding the motor, most $1 toys have one in it, even most HappyMeal toys... I tend to toss all my kids' McDonald's toys in my shop and cannibalize for motors, switches, LEDs, etc... AFTER they've finished playing with them of course!
Aug 5, 2009. 10:37 AMjuggler4real says:
thanks for the info
Jun 30, 2009. 7:22 PMcrossfrost69 says:
How do you buy stuff from the cherry site? because, i find the switch but then all it does is gives me info about it and doesn't say anything about buying it.
Jul 1, 2009. 11:22 AMcrossfrost69 says:
Can some one please tell me where i can get spdt switches like that other than from All Electronics, how do I order from Cherry? PLEASE REPLY
May 23, 2009. 2:26 AMranger_ijo says:
do the motor work in 1,5 v (i mean just one battery affect one motor) ? because i only have motor that can work in 3 volt...when i connect my motor in 1,5 v (1 battery)..my motor cannot work.. i have been searching motor that can work in 1,5 volt..but it's so hard to find...
Apr 20, 2009. 8:05 PMhotbabe3133 says:
how do i make a remote control or somethng like that... im in this competition to build a robot that can travel across the moon...... plz help me and fast........
Nov 18, 2008. 5:29 PMdawayne1 says:
hey dude how can i control it wat can i put in there to control and also do i need on and off switck
Jul 2, 2008. 1:50 PMbar513 says:
!!!great instructable!!! it's a very cool idea with very cheap parts! i like it! wish me luck XD
Oct 14, 2008. 5:17 AMsmilespoon says:
tHANKS MAN!ill win for sure with this
Jul 25, 2008. 8:47 PMmaRiigeL says:
Where can I find the 1.5V motors...? I know the rest is in radio shack but not the motors..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
229
Author:robomaniac(www.JeromeDemers.com)
I am a French Canadian that loves robots and embedded electronics. I work on all kinds of cool projects, like a high-power electric push scooter controlled with an Arduino. Please visit my website fo...
more »
