Step 16The BeetleBot v2 ( Revisited ) - Mounting the power switch
To stop your robot, you need to remove the battery. This can get annoying and I recommend adding a simple switch.
Look at the pictures and you will understand. I have added heat shrink to make it look nice and hide my beautiful solder joint.
and you soldered the same wire to the switch and attached another wire to the motor to the switch.. i am lost now :(
with NO switch
or
with a switch
if you want NO switch, you simply don't check that step. Leave the wire from the back of the battery to the motor.
if you want a switch, you will need to cut the wire and attach a switch to it.
i installed a switch and had mine working fine, until for some reason, the motors wont reverse...the just stop
also, when the on/off switch is off and i press a motor switch, the motors don't do anything! :(
Please reply!!!
