How to Build a Spangen Helm.
 by armourkris
Featured
In the past People have asked me to put up an Instructable on how to build a helmet. So, for all you people, Here goes.
As the title says, this Instructable will deal with building a Spangen Helm. Since I wanted something a little more unique I went with a 5 panel instead of the standard 4, and used shaped bands rather than straight ones.
Although the finished helm has a bar grill I neglected to add a bar grill step to this Instructable. The reason for this is that it was my first bar grill and I had a surprisingly difficult time making it. Until I've gotten a little better at them I don't want to try and teach someone else how to make one.
Step 1: Tools and Supplies I Used
Here's a list of what I used for this project. Not everything here is mandatory, a lot of these tools could be dropped entirely or else have other tools substituted for them.
Patterning supplies
- A Sharpy
- A Meter Stick or Straight Edge.
- A Fabric Tape Measure
- Scissors
- Empty Cereal Boxes, Bristol Board, or something of that nature.
Steel
- 14 and 13 gauge sheet metal.
- About a foot of 1" flat stock
- About a foot of 1/2" flat stock
- About 3 feet of 1/4" round stock
Cutting tools.
- A Jigsaw
- Aviation Shears
- A Chisel
- A Drill and 1/8" Drill Bit
Shaping Tools
- A Deep Dish
- A Shallow Dish
- A Dishing Hammer
- A Cross Peen/Machinists Hammer
- A T Stake
- A Ball Stake
- An Anvil Shaped Object*
Riveting Supplies
- A small Ball Peen Hammer
- Nails
- Side Cutters
- Cleco temporary rivets and pliers
  OR Small Nuts and Bolts.
Finishing Tools
- A Belt Sander
- A Bench Grinder
- Files
- A Planishing Hammer
*most any large hunk of steel will work for this.
Methelas says: Feb 6, 2011. 7:56 PM
Good to see more SCAdians here on instructables. I thought i was one of very few.
Methelas in reply to MethelasFeb 7, 2011. 1:34 PM
Which reminds me, about how much would you sell that helm for, i'm looking to buy a new one.
armourkris (author) in reply to MethelasFeb 8, 2011. 4:21 PM
I know there are a few of us kicking around here, but the more the merrier. i think there is a group of SCA related instructables even.
I've actually still got that helm for sale, I'm asking 300 for it. For custom work the price goes up a you get fancier, and down to 150 for a bare bones 4 panel spangen.
southerngent in reply to armourkrisFeb 10, 2011. 2:13 PM
Do you know where the scadian list is on here?
dreamberry in reply to southerngentApr 11, 2012. 3:44 PM
http://www.instructables.com/group/SCA/
armourkris (author) in reply to southerngentMar 10, 2011. 5:39 PM
I'm afraid I;ve never been able to find it on purpose. I just stumble across it by acident once in a while and never remember how to get back to it when i want to.
OldOwlIronworks says: Mar 7, 2011. 11:38 AM
you may have mentioned this in the instructable, but are your rounding dishes/swages made of aluminum or lead? did you make them? and how? I'm working on maille for a replica of the Gjermundbu helmet. you also may have mentioned this, but what is the best gauge of steel to work with, for a "battle ready" helm? or even armour. I have plenty of 16 gauge and some others... Thanks :D
armourkris (author) in reply to OldOwlIronworksMar 10, 2011. 5:35 PM
I've got 3 dishes, deep, medium and shallow. I made the deep dish by welding a sheet of 3/16" steel over a section of 4 inch pipe, then I heated it up and bashed it into a dish with my shot-put on a stick. I used the backside of it as a mold for my medium dish and poured down melted tire weights into the backside, let it cool and knocked it out, the shallow dish is just the bottom couple inches of a coffee tin with melted tire weights poured in then i just bashed away at it with my dishing hammer till it was about 1/4 inch or so deep. the tire weights are some kind of lead alloy. it's harder than straight lead so it holds up pretty good for dishing into. plus, with a bit of time you can scrounge them up for free off the sides of roads and whatnot.
As for what thickness of steel you want to use, well, that depends on a few things, what kind of use will it see, how hard will it get hit, are there pre-set requirements you need to meet. MY sca heavy helmets are all made from 14ga, my rebated steel helmet is 16ga, and my bike helmet is 18ga.
for a bit of a general guideline, assuming you're using mild steel, I'd go with...
Helmets 16 gauge minimum if you plan on getting hit, 14 gauge is better still. the weight is what stops you from getting a concussion after all.
For gorgets(neck armour) 18 gauge is usually a safe bet.
for 1 piece breastplates i use 16 gauge
back plates i go with 18 gauge
faulds and tasstes i use a mix of 18 and 16 gauge.
multy-plate breastplates and coat of plates style armour i use 18 gauge
spaulders/pauldrons(shoulders) i use a 16 gauge main plate with 18 gauge lames
elbows/knees are usually 16 or 14 gauge, with 18 gauge lames
vambraces (forearms) i use 16 gauge for the bottom half, and 18 gauge for the top.
rebraces (upper arms) i usually use 18 or sometimes 16 gauge.
cuise(thighs) I use 16 gauge, sometimes with 18 gauge wrap plates
greaves(shins) i use 18 gauge
sabatons(feet) 18 gauge, maybe 20.
gauntlets i usually mix 16 and 18 gauge
scale and lamellar armour i use 20 gauge, 18 at the thickest, but weight adds up fast with these.
in the end you're trying to find a ballance between coverage and weight. My current harness covers me from head to knees, minus my upper arms. it weighs about 60 lbs, i figure that adding greaves and finishing off the upper arms will bring my up to about 70 lbs. I only weigh about 150. I feel this is pretty reasonable for a full suite of plate armour, then again, i also like throwing 3 or 4 days worth of gear on my back and slogging up steep mountains, so what works for me may not work for you.
wow, thats a long comment now, hope something in there helps.
OldOwlIronworks in reply to armourkrisMar 16, 2011. 7:27 AM
Oh yeah another quick question :D
I have my templates traced on the 16 ga. steel, and in the book "medieval armor reproduction" it said to use a beverly shear Or a jigsaw...can I use a plasma cutter? I have a small jigsaw, but in short, it sucks, and I do have access to a plasma cutter.
Thanks
armourkris (author) in reply to OldOwlIronworksMar 17, 2011. 8:04 PM
yea, go for the plasma cutter, they're fun tools. really you can use anything that'll cut your metal, I usually use a jigsaw, tin snips and cold chisels, but only cause I don't have anything better.
OldOwlIronworks in reply to armourkrisMar 18, 2011. 12:30 PM
I was also thinking about Acetylene, but I am kinda afraid that'll take a bit too much metal off, I guess it can't hurt to try on some scrap
armourkris (author) in reply to OldOwlIronworksMar 18, 2011. 2:38 PM
I wouldn't bother using acetylene for cutting sheet metal, you'd need a tiny tiny tip for the thickness you'll be cutting, and you'll probably be left with a lot of cleanup. in my experience oxy fuel cutting isn't really worth wile for anything thinner than 1/4". That said, if you put down nice welds with it it's great for welded pieces and bar grills.
OldOwlIronworks in reply to armourkrisMar 10, 2011. 8:15 PM
Thank you! That helped quite a lot! I will have to make some dishes now; scrapyard trip :D
Giesterfarher says: Mar 11, 2011. 7:01 PM
A Whitney punch is the only way to fly for me. Center punch the holes, then punch them with the Whitney. No burrs to clean up, and no file scratches to smooth.
Mrballeng says: Jan 9, 2011. 6:02 PM
Have you ever tried your hand at making a container. Some type of chest, box, or keepsake? Good work.
Rozarius in reply to MrballengJan 10, 2011. 8:57 AM
I've thought of it, but no, I've never actually gotten around to making anything that wasn't armour
armourkris (author) in reply to RozariusJan 10, 2011. 8:59 AM
and i should really start to check whether me or the room mate are logged into instructables before replying to questions
JP50 says: Apr 15, 2010. 9:01 PM
Great job!  I need to ask what type of rivets are you using  and  where are they available?  I have done lots of welding,  gas and mig,  but have never seen that style of rivet.  Thanks.
armourkris (author) in reply to JP50Nov 23, 2010. 10:39 AM
since i cant find anywhere in canada selling affordable rivets i just use plain old bright finish nails, i get them is the shortest lengths i can in 1/8" and 3/16" diameters, i know 6d is 1/8, but i cant remember what the 3/16 is off the top of my head. from there i just clip them down to length and peen them like any other solid shank rivet.
check out my riveting instructable for more retailed info.
http://www.instructables.com/id/How-to-peen-a-rivet/
armourkris (author) in reply to JP50Apr 16, 2010. 3:15 PM
Just what pietseekoe said. they are 6d nails cut down to length and hammered down.
pietzeekoe in reply to JP50Apr 16, 2010. 10:13 AM
i think he just uses nails that he cuts and then hammers down
Rune Cutter says: Apr 27, 2010. 4:52 PM
What may help you on your bar grill is a wooden swage plate, I'm going to write an instructables on one one as soon as I get pics, but I drew one up for you.
It's just layered up plywood glued together, mine's about 10 years old and has seen weekly use.
If you lay your bar grill out flat and weld it together first, then shape it, things are alot easier, use the swage plate to get specific arcs, make yourself two or three of various sizes.  They are great for shaping vanbraces and grieves or anything else with a uniform curve.
armourkris (author) in reply to Rune CutterNov 23, 2010. 10:34 AM
hat is a brilliant idea, I;ve been wishing I had something like this for a long time, but it never occurred to me to make one out of layered plywood. I guess I;m going to have to scrounge up some plywood now
wulfric says: Nov 8, 2010. 12:40 PM
Wow your spangen is quite good, but if the marshals have a good look at your rivets they may not pass inspection. There is a company in the States called McMaster Carr, They sell solid steel rivets that one can't seem to find in Canada. The problem is they don't ship up here, but if you have a friend or whatever to ship them to they could forward them to you, or bring them across for you when they come up for a visit. The iron in nails is just too soft to hold up to SCA combat. Very good looking work keep our fighters armoured and on the field.
armourkris (author) in reply to wulfricNov 23, 2010. 10:29 AM
I've built all my own kit for the last 10 years, and built gear for a number of other people as well. I've never had a rivet fail, or had a marshal say anything bad about my rivets, I;ve even told a few of them that they're made from cut down nails. it may just be my part of the world, but i gather it is a fairly accepted practice. I also tend to over build things though, so that may be weighing in on my favor. I believe current regs state that rivets can be no more than 2" apart on helms, but on this one they are spaced at just under an inch apart.
that said, on moving parts like elbows and specially knees I'd move up to a 3/16" nail.
Thanks for the heads up though
curt-fullmer says: Nov 17, 2010. 10:50 PM
awesome. Great work
domamir says: Sep 26, 2010. 8:32 PM
I have a question. Is this a SCA legal heavy combat helm?
armourkris (author) in reply to domamirSep 27, 2010. 7:31 AM
It is indeed. now i just need to find someone to buy it.
domamir in reply to armourkrisSep 27, 2010. 4:24 PM
Where are you located? All you really need to do is go to your local fighter practice and you may find some who would want it or some other type of helm, or arrmor parts.
Bodygard1117 says: Jul 22, 2010. 3:01 AM
Have you ever thought of making small ones and selling them at craft fairs? You could make them out of tin that would reduce on the cost and the time spent on making them being that tin is enormously softer than steel. I am currently making a full sized one out of copper that i had laying around so i hope it comes out the same. Over all this is a great Instructable it is very detailed and has a lot of good quality pictures which is good for a visual learner like me. Keep up what your doing i hope to hear more from you.
unanonymous says: Jul 13, 2010. 9:03 AM
awesome now if only i could convince my dad to let me make this(i use his account)
the_burrito_master says: Apr 10, 2010. 6:02 PM
hmmm I wonder what gauge sheetmetal that is used for making duct work is.
my dad has like 300 plus square ft. of scrap metal.
I know you don't entirely need a dish but how would I get or make one?
armourkris (author) in reply to the_burrito_masterApr 10, 2010. 8:53 PM
most duct work steel I've seen is around 20 gauge, that said there isn't any reason you couldn't make a dress helm out of steel that thin
the dish that i made the majority of this helm with was made by melting down a bunch of tire weights i scrounged up and pouring it into a coffee tin. Once it had cooled off i just cut the tin off about 1/4" below the level of the lead then i just hammered stuff into it untill a shallow dish formed. i think it;s only about a centimeter deep.
other ways of building a dish range from carving or cutting a bowl out from a stump. I used to have a chunk of cherry wood that i cut a bowl into by repeatedly plunge cutting into it with a skill saw, I;ve also got a dish made by welding a piece of 1/8" steel over some 4" pipe, then I heated it up with a tiger torch and bashed it into a dish with a shotput. the deep dish i use in this instructable cast lead again, but using the pipe and steel dish as a mould. Another common way is to call up some compressed gas companies and find out what they do when they dispose of old tanks. most places cut them in half and toss them or sell them for scrap. if you can get the bottom half of an old cylender they usually have a nice ready formed dish in them, just weld a bottom on, or stick it in a barrel of sand, use a dremmel to clean up any lettering sticking out form the dish section and you should be good to go there.
so yea, dishes arent to tricky, most anything bowl shaped and tough enough to hammer steel into will work.
For shallow cirves like in this helmet you could also probably go the sandbag route. just take a pair of old jeans, double up the legs, stitch one end shut really good then fill it 3/4 or so with dry sand or bb's, or buck shot or anything like that and stitch the other end up. lay it out like a pillow and you can do light dishing into it,
the_burrito_master in reply to armourkrisMay 31, 2010. 11:06 AM
Finally got around to making a dish!
I cut the bottom of a refrigerant tank off and hammered the bottom into itself. it dishes amazingly ,I  cant believe how easy it has become. only problem is it had 3 nubs on the bottom that I had to hammer down and they made little warps in the dish I didn't notice any problems as I dished a little piece of metal...
Demascus in reply to armourkrisApr 15, 2010. 9:15 AM
duct work steel is about 20 g  your correct, it is a bit thin for anything except a dress helm and difficult to dish without crinkles. I found sheet steel cut outs from a custom van place and it is 16g. and dishes nicely
I was out at one of my local auto wrecking yards and found several "dead" H tanks the big type they use for welding and Co2 fire control banks. These had been drilled and dumped for scrap. I had them cut off the very end of the bottom about a foot from the bottom actually. The bottom of these tanks are very heavy and have a perfect "dished" end in them. A little work with a wire wheel and it was perfect. I have an anvil so cut two notches out on it so it sits down in a little slot there on the Anvil. I make helms all the time on it as well as shoulder pauldrons and Knee and elbow cops.
the_burrito_master in reply to armourkrisApr 14, 2010. 12:26 PM
whoa! Dude thanks my dad has a few gas tanks! I cant believe I never thought of that. Thank you so much.
A tree stump sounds good to me too
Copying this into note pad.
armourkris (author) in reply to armourkrisApr 10, 2010. 8:55 PM
I should also add that once you start getting thinner than 18 gauge dishing steel gets a little bit more difficult. this is because the edges tend to want to crease and wrinkle. So long as you stay on top of the wrinkles and hammer them out when you see them forming you shouldn't have to much trouble though.
skimmo says: May 27, 2010. 4:23 AM
 are you a panel beater?
the_burrito_master says: Apr 25, 2010. 1:57 AM
Here's how mine turned out. pretty good for my first....
still need to burnish it.
My grill is made of copper cubes ,riveted to the frames.
Rune Cutter in reply to the_burrito_masterApr 27, 2010. 4:54 PM
Super Job! much better then my first that was mistaken for a trash bucket
the_burrito_master in reply to Rune CutterApr 29, 2010. 10:17 AM
Lol , thanks.
armourkris (author) in reply to the_burrito_masterApr 25, 2010. 8:24 PM
That's really good for a first. My first helmet ended up half finished in a scrap bin when i realized that it was about 10 sizes too big for me, and not really shaped like a head.
If you got the helmet put together this good then spaulders should deffinetly be no problem for you.
Thanks for posting pics, It;s awesome to see other peoples work.
the_burrito_master in reply to armourkrisApr 26, 2010. 12:07 PM
that reminds me ,once i did try to make a  helm out of just one piece of metal. it was like a square shaped helmet with a partially circular top... or that was how it was planned to be. Icouldn't dish the top enough to close it up and i couldn't even weld like I planned on doing.
lol so I still consider this a first :P
the_burrito_master in reply to the_burrito_masterApr 25, 2010. 11:24 AM
I meant "copper tubes".
Metrica says: Apr 28, 2010. 10:38 AM
I wish they had a "like" button or a thumbs up because this is great!
the_burrito_master says: Apr 21, 2010. 8:35 PM
Just got the nose plate on finally figured out how to properly rivet the nails so the top half is gonna look like it was worn though many battles. Oh well it's my first metal crafted anything.
My pauldrins will be better
the_burrito_master says: Apr 19, 2010. 8:45 PM
it's too bad I ran out of rivets... lol and the nails don't work because the holes are too big and the metal is too weak. but I have the front most pannel secured and all the res dished and ready to be drilled.
the_burrito_master in reply to the_burrito_masterApr 20, 2010. 9:50 AM
I just drilled all the holes last night ,the easiest way for me to do it was to get a   metal hole puncher ,and start with the helmet frame  ,not the panels, and punch out all the holes I'd need. Then take a sharpie line up the panels just right clamp  them in place and mark out the spots to punch.
armourkris (author) in reply to the_burrito_masterApr 20, 2010. 1:54 PM
Thats the same way I did it, I;m pretty sure thats how i say to do it in there as well.
It looks like your helmet is coming along really well.
the_burrito_master in reply to armourkrisApr 20, 2010. 9:51 PM
Oh it is , aww well  guess I misunderstood... well even still it's workin' out great for me.
Just one more panel to go the left side was too small after I dished it :P
BTW dishing in the hard dirt made all the difference. I could make all 5 in the time it took me to make one on the knee pad.
darkbain says: Apr 15, 2010. 8:15 PM
Great work, very very well layed out and highly detailed.  I wish I had the place to make a helmet like that.  It looks official man.  I'm trying to figure out how your Burnisher works.  Can you explain it a bit?  Also, thanks for displaying the Clecos.  I will be looking for a set on ebay.  I see how they can be of great use.  Thanks for posting this.
armourkris (author) in reply to darkbainApr 16, 2010. 3:17 PM
The burnisher I use is basically a big tumbler. I toss in my plates, load it up with steel ball cones (think ball bearings shaped like UFO's) then add some water, a little cutting fluid and let it run over night.
the_burrito_master in reply to armourkrisApr 20, 2010. 9:38 AM
hmm so that's what it is so I could get the same look jsu by using  coarse wire drill bit?
armourkris (author) in reply to the_burrito_masterApr 20, 2010. 1:53 PM
with some time and effort i'm sure you could get something pretty similar.
Rune Cutter says: Apr 13, 2010. 10:16 AM
Very nice, I've been armouring for a very long time, the Spangen is one of my favorites but I moved on to welded because it's less work intensive.  You've convinced me to to take a stab at this one again (5 panel) I used to do 6 panels, the rivets take a bit extra effort and time but the appearance is absolutely worth it.  I love the finishing dish you put on the tassets in the back, it adds to the appearance and relative strength.  Very nice craftsmanship, good attention to detail,  I would give you very high marks in a A&S competition.  I'll need to mod mine for lives steel but you gave me some things to think about.  Thank you very much.
sublingual in reply to Rune CutterApr 20, 2010. 7:05 AM
Very nice, indeed. Great attention to detail and I-ble writeup.
Speaking of modding for live steel, if any live steel (or Dagorhir/boffer) folks want to try this out, for God's sake wear an arming cap and/or pad the dang thing. ;)
Kryptonite says: Apr 18, 2010. 1:32 AM
My friend's father does helmets for viking events and they always turn out amazingly well. I like how you decided to write yours up, looks good!
static says: Apr 17, 2010. 9:54 PM
 Beggining metal artists should condider making a "shot bag". A round leather bag with box contruction sides filled with lead shot. Used with a hammer to create concave shapes in sheet metal.  Google the term to find photos of some for sale.
scree says: Apr 11, 2010. 9:45 AM
 Sweet jesus. I don't think I have the oomph to make an instructable this good much less that freaking awesome helmet. Well done all around. Any recommendations of a simpler project for someone trying to break into the metalworking thing in general?
armourkris (author) in reply to screeApr 11, 2010. 10:05 AM
Armourwise? I'd recommend a Spaulder. Spaulders are a kind of shoulder and upper arm armour. At their most basic the pattern is 3 or 4 rectangles and a D shape. if your interested in that send me a message and i can give you some more detailed instructions.
dstras in reply to armourkrisApr 15, 2010. 10:59 AM
 would you be willing to share those instructions here? I'm looking for a good intro project to do with my son.
great job on this -- both inspirational and helpful
armourkris (author) in reply to dstrasApr 16, 2010. 3:27 PM
http://www.armourarchive.org/patterns/pauldrons_ab/
there is a basic pattern, the armour archive also has an amazing set of forums.
I think construction wise it's pretty self explanatory, dish the top, just bend the lames, flare the lower edges if you like, and then rivet it onto leather straps. but if you have any question just let me know.
the_burrito_master says: Apr 16, 2010. 2:30 PM
Just a little status update I'm currently on step 4 picture 28 and it's coming along great.
I am actually doing my dishing on a gardeners pad like one of those mats that you kneel on... it works pretty well but I doubt it would work with higher gauge steel.
captain Jack says: Apr 15, 2010. 9:57 AM
holy crap that was an amazing job!  VERY well documented!  Congratulations.
ilpug says: Apr 13, 2010. 8:18 AM
 bleacgh. joni mitchell. on a lighter note, nice helmet.
DerStu says: Apr 9, 2010. 1:52 PM
Looks great, most people weld in the bars, it might be easier but does not look as good as rivets, awesome job! You realy need to see about comeing down to June Faire the Queen will be there fighting
armourkris (author) in reply to DerStuApr 10, 2010. 12:12 PM
I actually wanted to weld the bars in place, but the welder I've got access to is such a dodgy POS that i don't think i could have done it without really mangling the cheek plates. June Fair sounds like fun, but i'll have to see how work and school goes.
DerStu in reply to armourkrisApr 11, 2010. 10:37 PM
I hear you I have work to do on both my welders (mig and stick) but it still looks good you also might consider brazing the spangens in on the back side for added strength.
if you haven't seen it here is the SCA URL for June Faire http://www.dragonslaire.org/Events/junefaire.htm
thepelton says: Apr 10, 2010. 3:06 PM
Wunderbar!
SinAmos says: Apr 9, 2010. 5:02 PM
You make me want to pound metal.
armourkris (author) in reply to SinAmosApr 10, 2010. 12:14 PM
Then pound some metal, with a bit of scrounging a basic shop can be set up pretty cheap. I think i first started armouring with a budget somewhere around $50.
keiou says: Apr 10, 2010. 4:16 AM
 Good job!
usLEDsupply says: Apr 9, 2010. 1:26 PM
Wow this looks truly amazing!
Frogzard101 says: Apr 9, 2010. 12:15 PM
Bravo!!
Bongmaster says: Apr 9, 2010. 6:57 AM
awesome :)
HeWantsRevenge says: Apr 9, 2010. 12:27 AM
this is jus amazing
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
