3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build a Super Top Secret Bunker under Your House. The Prelude...
  • last photo ←
When I built the house I just spent 7 years working on, I had a lot of days that were just plane monotonous, so I would daydream about the Next Great Project as soon as I finished the house...
If you're OCD you know exactly what I am speaking about.
Perhaps it was watching too many reruns of Stollag 17...
Maybe it was all the Underground cabins we built as kids to have a cool place to hide out in the summer.
Truthfully though I just love to build things and when I designed the house I made the bottom level only half the size of the main floor and the other half is a crawlspace about 4 foot high.
Most of my plumbing and stuff runs around the floor joists down there so I wanted enough room to have access to everything but I didn't want to build an eight foot wall, It took me 7 weeks to do the block for the garage workshop and storage room so saving 4 feet of wall seemed like a good idea.
Looking back if I really intended to do this and had the wife's permission I could have saved a lot of bother by doing this first and I wouldn't have to worry about the house falling on my if I dug out too much from below it.
I didn't leave any vents to the outside mostly cause of wanting to be energy efficient and not have a cold room under one above I was trying to heat in winter. I did talk to the building inspector about this and convinced him I could put a gable vent fan on a timer at each end one blowing in and the other blowing out to ensure a good change of air so it never mildews. I intentionally made it to push air into my workshop and draw replacement air under the house at the far end of the garage. This way in the winter when I am using the wood burner if I am working on something I can open the duct to the workshop and close the damper and the heat travels in a big circle across the garage into the crawlspace and then back into the workshop to circulate the heat so I can work on something midwinter if it is 40 out with a t-shirt on.
I got lost in a Blizzard when I was abut 20 for 23 hours and was 31 miles from where we parked when found, so I don't do cold anymore...
When I laid out the supports to the crawlspace I left a wider gap between two of the columns supporting a beam since the crawlspace is 20 foot wide and I didn't want to pay to special order 20 foot 2 by 12's and I just happened to have gotten a deal on a couple 40 foot beams delivered by accident to my house and unloaded before we discovered they loaded the wrong ones and were two thin to support the bottom garage ceiling. They sold me them to me at cost when they delivered the proper beams a few days later because it would have cost them money to rent a piece of equipment to lift them back on the truck.
I also filled the back of the bottom garage wall wide enough for a ten foot door and didn't put any rebar in that section. All the rest of the bottom level block has rebar in ever other hole and is filled to the top with concrete instead of just every 4 feet as code calls for. I will be able to saw this opening or get some of that ACME black paint they use to make tunnels and then start digging with a bobcat and dumping the dirt on the slope behind the pool so its not as steep a grade since I use a push mower for the exercise.
http://www.flickr.com/photos/senseless_/sets/72157600030895157/
Related Instructable's
http://www.instructables.com/id/One-Method-of-Removing-Soils-from-the-Top-Secret-B/
http://www.instructables.com/id/The-Super-Top-Secret-Bunker-Project-Video/
Step 1Different Methods of Moving Soil and Reinforcing Sides
  • last photo ←
When I started thinking seriously about starting this I knew I had to do a few simple tests first that would cost me a bundle if I had to hire an Engineer and do them even before I applied for a permit.
They'd want to know the different types of soils, how thick each seam was and most importantly I wanted to know how far down the water table is.
I live in Florida and generally if you dig a hole a few feet down you'll hit water but I'm in the Panhandle of Florida so we actually have some hills here. The lot slopes to the lake enough I was able to dig a bottom level into the hill giving me a pretty safe place to hide if we get a bad hurricane. The house is extremely reinforced and all the walls are shear walls meaning at least one side has plywood glued and nailed every four inches, including a second layer on the inside of the outer walls which also went a long way to soundproofing the place. I have more anchors than required and threaded rod going from the footers to the trusses including the interior walls.
The molding work on the ceiling of the great room is actually tied into the roof trusses and the floors are all 3/4 plywood tongue and groove and glued and nailed plywood every four inches for a subfloor. It's covered by 3/4 by 2 1/4 Oak tongue and groove running perpendicular to the floor joists. The Kitchen, Halls and Bathrooms I tiled but the bulk of the house has the Oak making a very stout roof for the bottom level.
My workshop also has plywood ceilings so that part is especially strengthened to the point of a tornadoes shredded the top two floors you'd be safe huddling under the work benches.
I tend to ramble because I crushed my head three years ago in an accident so back to the intended topic of how to dig a hole under a house and not have it fall on me.
My primary method was that I felt I could safely dig along side of a footer and pour a 2 foot high concrete wall so long as I did it in stages the sides would not cave in for a few day, especially if I misted it with water from the hose. I drove rebar about a foot into the sand or clay and left the rest sticking out the top so the final bottom to top pour would bind everything together. I also after the concrete had dried and I had the forms moved down another 2 feet I would use a small spade to find the bottom of the previous rebar, and using a piece of pipe for leverage I'd bend it into the area of the new pour at a 45 and then bind it to the rebar for the next pour. The end result is a very solidly secured concrete wall 10 or 12 feet high shaped like an inverted wedge to discourage it from sinking into soft ground. Also I decided to only do 10 or 15 feet at a time but never the length of an entire wall in one shot so I didn't have the sides blowout like in a mine accident.
I spent 7 years building the house I don't want to cause it to collapse and the wife would never let me hear the end of it.
I then figured I could keep repeating the process essentially forming a very tall staircase and when I had enough head room I'd pour a final layer 8 or 10 feet high to tie it all in. Billy down at the building department would have a fit if I told him I wanted to do this and I'd need a real engineer to put their stamp of approval on it and it's not the type of job you can start and walk away from halfway done if something comes up, so this is too much for me to do as a solo project and I;m not actually Licensed Florida Contractor.
I did figure I should do a test shaft to see if it actually worked and get a record of what was down there and I would definitely need to know the water table height and the thought of having to assemble a mini drill rig in a crawlspace seemed pretty expensive but by staring long and hard at it for a time and a day, I decided I could dig a shaft by hand right next to the access port and cover the stairs with a snug piece of plywood then shovel it out the port onto the stairs then into wheel barrows and dump it out back.
How hard can that be?
I had a limited budget but I do own a mortar mixer and had a great stockpile of rebar and three inch pvc pipe left over from something I cannot recall and some lumber I'd used already for concrete forms and yes there is a Plus side to OCD especially if you have the room to store it until you need it.
I chose not to mention to the wife what I was planning mostly because she would have said no but I had just about used up all my savings finishing the house but I still had my emergency $1000 so I did some math and bargained for a lower price on 80 pound sacks of Redi-Mix if I bought 6 pallets and so I snuck a look at the wife's calendar to see her next doctors appointment and her caregiver would drive her so I set up the deliver for when she was gone and had a space cleared in the bottom garage that I could store all of this, and had some pieces of pipe on hand to walk like an Egyptian and move the 3000 pound pallets to the far back of the garage by rolling then and then using the next pallet to roll the first to the back until all six would be safely hidden inside.
The wife was running late though and they showed up just as she was leaving...
Fate Strikes Again but my wife knows I was still not quite right in the head in fact she'd say I was like that even before hitting my head and is used to me just jumping up in the morning to start working on something and I did after all build her a house and miraculously she didn't ever really ask me what the cement was for.
Once I had the cement I thought about forms and I decided if I am to do this and make a 2500 square foot bunker I need the forms to be modular so I could keep reusing them over and over.
I decided on a few basic sizes, 2' by 8',2' by 6', 2' by 4', 3' by 4', and I made them with the braces in each size identical so when I needed to make 50 of these I could drill around the perimeters in a standard pattern so I could just bolt these together, pour the concrete, then unbolt them the next day and move on. Trial and error taught me that staple gunning a smooth layer of 6 mill plastic makes for a much smoother wall than plain plywood and you just need to replace it every few pours.
With the forms made and the 6 yards of concrete safely hidden and covered with a tarp just to be safe I started digging next to the access port so I could get some standing room. The first five feet of soil is sand I believe referred to as Orange Ruffie but I'll need to check my soil survey of Walton county to be sure.
Regardless sand is pretty easy to shovel although the very top layer was had dried out pretty solidly and had some clay mixed in I had to spray it with the hose to soften it up. You actually need to keep the sand moist or the sides will cave in quickly and I made a point of misting the ground before I quit working on it for the day.
I made this approximately 7 by 7 since as I went deep it would get narrower and I was about 18 inches between two columns supporting the beams so this was a good spot to test. On the first 2 foot pour I also poured and formed a beam between the columns with a lot of heavy angle iron cut to fit tight between the columns.
The I started getting the hits from The Office of Homeland Security which I figured was just because so my of my traffic comes from Walter Reed Hospital and the rest from our troops abroad.
Then the cable company knocked on my door and said some magic piece of equipment let them locate the source as somehow coming the crawlspace under the house and they needed access under there to check for problems...
http://senseless.livejournal.com/229844.html
165 comments
1-40 of 165next »
Aug 21, 2010. 2:02 PMthepelton says:
I just finished reading "The Tunnels of Cu Chi" about a labyrinth of tunnels in the area northeast of Saigon used during the Vietnam war. It appears that two things you would have to be sure of before beginning your little postapocalyptic hideout are the consistency of the soil, (the Cu Chi soil was hard enough to withstand tunnelling), and the other thing is the water level (the water level was sea level, (Cu Chi area was high enough it didn't seep in.) Otherwise, you would need to pump constantly, which would use up a lot of power. In some places, like suburban District of Columbia, the water level is about three inches down.
Aug 26, 2010. 7:01 AMstiggle says:
You'd just need to "tank" it to be watertight which is installing a waterproof membrane on the walls. Then you just have to be careful not to puncture the membrane. There is a guy in the UK who "tanked" his basement... http://www.practicalfishkeeping.co.uk/content.php?sid=2951
Aug 27, 2010. 9:54 AMthepelton says:
One other useable thing that I got from that book was that the Vietcong made an occaisional room with a conical cieling. This worked like a megaphone to amplify sound going through the ground. You'd be able to know if someone was outside, looking for you, or if someone was driving over your hideout.
Feb 17, 2012. 2:55 PMtinker234 says:
bye anychance does some one know how to make a airtight seal
Sep 1, 2010. 12:28 PMsk8rforlife says:
im not trying to be mean but why did you make a top secret bunker?
Jan 8, 2012. 7:53 PMGrimmy Grim says:
Why wouldn't one make a secret bunker if it's possible?
Jan 8, 2012. 1:05 PMoctollama says:
It would be so cool to have a secret bunker under my house
Jun 29, 2011. 5:38 AMmaxsil says:
Wow, you'll probably be the safest person on earth during a zombie apokaplypse
Apr 19, 2011. 9:04 PMthumole says:
I used wood. I'll explane later.
I dug straight down for 18 ft. Then dug a 12X10 ft room with an 8ft celing.
For the guy who thinks you need lead to shield from radiation. Not so!
I'm an engineer having worked on Nuclear projects.
All you need is a good filter to keep out radio active dust, "that is what nuclear fall out is" you only have to worry about Gamma radiation.
A cinder block building will protect you from Gamma if you double them up.
I would if building above ground make a wall of cinder blocks with the holes filled with
either concrete or packed earth.
Then I would build another around this wall with about 20 inches of space and then fill the space with either concrete or packed earth.
Build for strength and build the roof with a layer of 2X12 inch cinder blocks. Some earth of approximately 20 inches then another layer of 2 inch cinder blocks.
Other than life support, "mostly filtered air" you are safe from radiation with this.
I went underground due to paranoia.
My hole is under my deck which is at my dining room level.
Below my dining room is a utility room that is the same size as the slab.
Extending out from my dining room door is a deck. There is a stair way up to the deck as the back entrance to the house.
The deck then extends all the way around the house.
Under the deck just exactly under my kitchen door is where I sunk the 36X36 inch hole.
The shape of the slab is not square. One side is slightly longer than the other.
The house is sided up from the slabe and the area where I have my hole is in the corner created by the long side of the slab and the short side. It just happens to be the slab is actually 42 inches shorter at one point. That is where I dug down. That made it easy to wall my hole in under the deck maiking it look as if the slab is square.
In side my utility room I have storage shelves along the wall that is the short part of the slab. I have redesigned the shelves so one of them is actually a live storage area. We store light stuff there, "cerial, rice, dryed milk etc." That shelf is actually movable as a hidden door to the top of my shaft.
I have storage for more than a year if I had to stay there 24 hours a day.
That includes my wife, ten cats and two dogs.
I have a way to dispose of the cat littter and other nasty stuff.
I have a filtered air system, including hand pumped back up system.
I have a "geiger/muler" tube monitoring system with one in my shelter and one exteded to the surface. The one on the surface is disguised.
I have an almost endless supply of water. I also have filters for incoming water if necessary to remove sediment that may be radioactive.
If biological I have CO2 absorbers and a large supply of pure O2 and monitors to know how much O2 to add as well as the level of CO2 in case I need to manually pump the air. I also have quite a bit of clean nitrogen to replace any lost over time.
My blend is nitrogen and O2.
I'll elaborate on the "how to" on digging this without getting burried, later.
Dig baby dig!
It's coming.
Not if but when. O
bama is putting the push on to destroy this country as fast as possible with his friends.
It is the absolute gole of the Progerssive, Communsts etc.
When it comes, I'm gonna be a casuality but the cost, "if I have my way about it" will be very very high.
I'm still digging, "expanding in sq ft." Off one conrner I'm digging a long tunnerl,
75' to another area for an emergency exit.
The shaft for the exit on this will only go up to about 3 ft below the surface and will be dug with renforcement on the way up.
It will only be completed if I need to dig my way out!
Thu Mole!
May 22, 2011. 8:05 AMjgarza2 says:
We are thinking very much alike! The 75' E-scape with 3' undug left for that time.I also thought leaving ammunitions at the end. I have a perfect place for digging starting under the house, I purchased 5 acres on a hill having 360 deg. view, yet the hill is alabama red clay. A very tough soil yet i couldn't ask for better. I am starting the dig this weekend. I am an electrician and have the supplies for a battery bank and wind and pedal generated supply for the bunker using all LED's for some light. Thanks for your ideas and good will to you!
Feb 26, 2011. 4:05 PMdildo69 says:
Did not understand what this project is. Want my nickel back
Jan 20, 2011. 7:29 AMpigsnfish says:
I've ALWAYS wanted a hidden, underground bunker. As for verbiage...you made me laugh and smile and believe that I could do this as well. It's a very detailed instructable, and I think that with your instructions, I could make a reinforced hole in the ground, too. Unfortunately, I get all the great ideas, but don't have skills with electric/mechanical tools. When I approach my husband with my grand ideas, he looks at me, his eyes glaze over and his jaw goes slack. I'm thinking I might just have to start secretly digging a hole (and I have the perfect spot) and when it's mostly dug out, I can employ his help. I think that it's wonderful that you'll be able to save yourself and your wife if you have to thanks to your bunker.
Jan 1, 2011. 8:11 AMRobert595 says:
Love the project, but wish that it was summarized with less detail as to what type of wood your floors are made out of, and more of what you did for THIS project. Also mentioning accidents that happened in your life just distracts from the reading, but its still a GREAT idea.
Dec 23, 2010. 5:07 PMmatt_and_nick says:
now i want to make one. but if i do, i'm lining the outside with lead. keep the radiation out.
Aug 28, 2010. 11:53 AMspecopps117 says:
:.( I always wanted to build things but I never able... never figured out why...
Dec 4, 2010. 10:19 PMspecopps117 says:
The only problem is that I live in the suburbs of a small town in North central Texas, and there isint much land to be bought to build/dig on...
Dec 2, 2010. 2:32 PMspecopps117 says:
Thanks man!
Soon as I get free time I'll try something...
Oct 29, 2010. 4:45 PMsuperalien271 says:
Now i know what i'm doing this summer!!!!
Nov 30, 2010. 6:16 PMHightechk says:
me too!!! lol
Sep 25, 2010. 6:59 PMHightechk says:
Hey i live in FL too but I'm on a pond. But the water raises and lowers 3-5 feet and you can dig about 7-10 feet, during different seasons i was wondering if i waited to low season and then made it water tight, you know with plastic and sealers and stuff on the outside before i did the cement, do you think that I could build one. Also, are there laws on this or is it like jut don't put up a giant sign. And you also have to use normal basement building codes, right? thanks for great Post I'm excited!
Sep 26, 2010. 12:40 PMHightechk says:
thank you, I'm hoping to get started this winter around december because the water is lowest then and its cool so i wont get heat stroke. i will post mine on here when i do it.
Sep 8, 2010. 6:09 PMspark master says:
Got this from another instructable very cool see the video's oh your wife is gunna hate me
http://www.hiddenpassageway.com/
sparkie
Sep 24, 2010. 5:06 PMHightechk says:
thats great im finding so many thing i need on this site lol
Sep 24, 2010. 5:05 PMHightechk says:
so cool I'm going to build one now
Sep 4, 2010. 12:13 AMsnarfle says:
you wrte stollog 17 i think its stollag 13 lol that is if your refering to hogans heros lol
Aug 29, 2010. 9:06 AMTimmah says:
Way too much verbiage, nice pics, cool idea. Next time just add verbiage to the photos.
Aug 27, 2010. 1:41 PMchuckw68 says:
It rubs the lotion on its skin or else it gets the hose again.
Aug 28, 2010. 7:37 AMrenscan2 says:
I love that movie!
1-40 of 165next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:Senseless
http://senseless.livejournal.com/ I've been attempting to build a house mostly by myself for the last five years... I finally more or less finished it before the bunker project and after recover...
more »
