Many hours thinking i came to a conclusion. If im going to be traveling through time, the actual time machine would have to be timeless (not out of place in the past, present day, or the future)
So eventually i decided to make something that resembled a time piece, mixed with an old compass, and various other inspirations, some from various steam punk items.
However i did not want to make something that was steam punk, as i personally find alot of steam punk to be a bit over comic like, and a bit to fantastical.
So, heres how i did it.
Materials consist of -
Alot of scrap and junk
corrugated cardboard
Mount card
PVA glue
Super glue
Black paint
Spray paint
Leather
Wood
Some thicker mount card
A few Special oddments - for me this was the lenses.
Remove these ads by
Signing UpStep 1Building a base
Firstly, i set about cutting out some ring shaped pieces of card, As you can see from the pics below.
Obviously, you could just create this thing from scratch using cardboard. But i think a good scavinge can always turn a good result - The metal sections in the first picture are off an old repromaster! bout 20,000 pounds worth of kit in there day ( we recently scraped ours)
I basically used these as a shape to trace onto the card.
Cut as many as you like to give it a good depth that your happy with.
I recommend corrugated card as it is easily to get a thick depth, its easy to cut, and great for gluing in later steps.
parallel dimensions
1) where do you get all those things are they from like home depot, or what.
2) how does it work, i mean you kinda just threw a bunch of random stuff in it and said tada
3) how much does all the supplies cost. Im young, so i dont have a job or alot of money but i would really like to make one.
4) DOES IT ACTUALLY WORK?!?!
I had hopes for this thing.
If you do I will be your No. 1 fan and will always vote for your Instructable in contests.
Currently planning to build it into a book, making it easier to blend into most times.
As a prop, though, it seems pretty good.
