3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build a Time Machine (Vortex Distortion Space and Time Dilating Device)
Well lets put it this way, ive always had this thing about traveling through time, and having a time machine. So i set about making one, i decided that instead of being a vessel to travel in, i would rather have something portable.
Many hours thinking i came to a conclusion. If im going to be traveling through time, the actual time machine would have to be timeless (not out of place in the past, present day, or the future)
So eventually i decided to make something that resembled a time piece, mixed with an old compass, and various other inspirations, some from various steam punk items.
However i did not want to make something that was steam punk, as i personally find alot of steam punk to be a bit over comic like, and a bit to fantastical.
So, heres how i did it.
Materials consist of -
Alot of scrap and junk
corrugated cardboard
Mount card
PVA glue
Super glue
Black paint
Spray paint
Leather
Wood
Some thicker mount card
A few Special oddments - for me this was the lenses.
Step 1Building a base
Building a base
Ok, now the base of my time machine was modeled around two ring type peices of metal, and as with the rest of the -ible, you kinda have to work things out for yourself too!
Firstly, i set about cutting out some ring shaped pieces of card, As you can see from the pics below.
Obviously, you could just create this thing from scratch using cardboard. But i think a good scavinge can always turn a good result - The metal sections in the first picture are off an old repromaster! bout 20,000 pounds worth of kit in there day ( we recently scraped ours)
I basically used these as a shape to trace onto the card.
Cut as many as you like to give it a good depth that your happy with.
I recommend corrugated card as it is easily to get a thick depth, its easy to cut, and great for gluing in later steps.
615 comments
1-40 of 615next »
May 20, 2012. 4:44 PMmdesgraciado says:
Greetings from the past... or the present. Damn, time traveling is confusing!!
Dec 9, 2011. 9:10 PMphysicsbreaklaws says:
lol there is no such thing as time travel there is only capabilities to travel between
parallel dimensions
Mar 24, 2012. 6:55 AMDeceptibotX says:
I think of time as a book. Every little detail is written in precise order on every page. You can go forward and skip to the end, or start over again or just keep going at the pace you are going. Technically, right now the Big Bang started, and technically the universe has ended. I would think that the real problem of time travel would arise when you try to rip a "page" out. Then anything goes. You are right in one aspect; time could very well be another dimension (along with thought and a varity of other things), but time travel is not impossible. I am not stating that as an opinion, but as a fact. You are time traveling right now, otherwise, you would be standing still.
Apr 30, 2012. 2:53 PMtinker234 says:
if evry parrel dimseion it could be a diffrent time so in theroy we travel into those and when we kill someone it does not affect our reality i have found about 40 diffrent ways to travel in time
Feb 17, 2012. 7:07 AMTheForkster says:
On the whole you are very wrong...time is a function of eternity,we are eternal beings in a state of mortality, we have witnessed the "past" and are experiencing the "present" and will after this experience return to our eternal state where we will once again see things as they really are...devoid of the illusion of time.But in mortality we shall not succeed in traveling to points other that the future...tick by endless tick.
Mar 24, 2012. 11:33 AMlooy99 says:
I have only four questions.
1) where do you get all those things are they from like home depot, or what.
2) how does it work, i mean you kinda just threw a bunch of random stuff in it and said tada
3) how much does all the supplies cost. Im young, so i dont have a job or alot of money but i would really like to make one.
4) DOES IT ACTUALLY WORK?!?!
Mar 25, 2012. 6:33 AMDeceptibotX says:
Gmjhowe said it was just a prop...
I had hopes for this thing.
Aug 3, 2011. 6:26 PManeet says:
:( how does it work...:(????????
Oct 17, 2011. 10:44 PMSockKreature says:
It works by distorting the time realm in half and forcing a gateway through to the past. It then merges the two dimensions until the two parts, you and the watch, are successfully transported.
Mar 24, 2012. 6:59 AMDeceptibotX says:
Geez, I'd love to see it in actiopn. PLEASE tell me you are not bluffing! There have been two dreams I've had; time traveling and touching the cosmos.
Mar 22, 2012. 4:26 AMdjhohen says:
All right everybody time machines that exist on earth are improbable due to the fact that if you travel into the past to chang sompthing it wouldent need to have been changed in the first place. So the slightest ripple in the time space continium would ultamently destroy all matter in a fourth dimentinal atmosphere. You can travel into the future by going clockwise arround the opening of a transdimentinal blackhole, you could also sleep for a long time :b
Mar 24, 2012. 6:46 AMDeceptibotX says:
Improbable, but not impossible. I have tht same thought almost anytime I think about time travel, but really, in physics, there is nothing stating you can't time travel.
Mar 24, 2012. 6:44 AMDeceptibotX says:
You know how chicken die suddenly? I need to make a time machine to save a few chickens, so can someone post their blueprints for a working one? I'm kinda lost on some aspects of technology....
If you do I will be your No. 1 fan and will always vote for your Instructable in contests.
Mar 20, 2012. 8:36 AMEzra Fike says:
I'm working on making this right now. I'm using parts from an old camera and a tape player. I'll tell you how it turns out. By the way, it looks wonderful!
Jan 7, 2012. 9:54 AMalecnotalex says:
It's funny how some people could even consider it working.
As a prop, though, it seems pretty good.
Feb 22, 2012. 6:12 PMAlecia294167 says:
It only describes going into The Past , Does It work for going into The future ??
Oct 1, 2009. 9:52 AMcryptex says:
step 4 pic 3 bit fuzzzy
Feb 15, 2010. 2:34 PMmason0190 says:
yeah...
Nov 28, 2011. 7:47 PMSaxtusBeta says:
No.
Oct 18, 2011. 10:32 PMnkra says:
time you can not really time your going to need to go into a blackhole the blackhole will make u go at the speed of light the mth of the blackhole that it is like a time travel sorry i am not saying this rit
Oct 22, 2011. 11:46 PM1999 says:
Or wormhole
Oct 22, 2011. 11:45 PM1999 says:
If not secure your body will be crushed from the wormhole and you'll die. . .
Oct 22, 2011. 11:44 PM1999 says:
In order to time travel you need to make a divice which you could get in and it has to be very secure because when time travel happens you enter a worm hole
Oct 22, 2011. 11:42 PM1999 says:
its not real guys but it looks cool
Jun 13, 2009. 11:12 AMSpacemonster says:
Dude, if that really really works ill mail you 50$
Jun 25, 2009. 5:18 PMtevers94 says:
lol, only 50$ for a time machine. I'd pay 55$
Sep 20, 2009. 10:04 AMReCreate says:
And send it with the lowest priority shipping, remember, it is a time machine. If it comes in a month you can go back in time to repay that time of waiting ;)
Oct 17, 2011. 10:47 PMSockKreature says:
But if you went back in time then you wouldn't have been able to get the time machine to go back into therefore you would cause a black hole O.O
Oct 18, 2011. 9:47 AMReCreate says:
That's why i prefer the time and relative dimension in space, handles the paradoxes just fine and dandy. Just don't go out and kill your grandfather.
Oct 18, 2011. 4:20 PMSockKreature says:
Ahhhh yes that would work great! I'll be sure to try that soon!
Jun 27, 2009. 5:51 AMSpacemonster says:
Uh, ?!$&@! Sorry just kidding! PS please put a video on showing it in use
Oct 18, 2011. 4:19 PMSockKreature says:
Its impossible to video a time machine in use.
Nov 23, 2009. 12:08 PMemedina94 says:
 OMG REALLY. REALLY!!!!!!!!!!!!!!!!!!!.
Nov 23, 2009. 3:37 PMtevers94 says:
haha
Jun 25, 2009. 10:08 PMquesoman says:
y not 60$?????????????????
Jun 27, 2009. 5:54 AMSpacemonster says:
be cause it is small
Jun 28, 2009. 7:00 PMtevers94 says:
but its a time machine
1-40 of 615next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
