Introduction: How to Build a Wall Locker
Picture of How to Build a Wall Locker
Now that our son is in Kindergarten we needed to get organized for the school year. We built this wall locker to help keep track of the important things... backpack, folder, and a chalkboard to remind us of upcoming events. This wall locker is a simple build and has been a huge help with staying organized.
Step 1: Cut List
Picture of Cut List
I've provided a cut list above to show the layout for the cuts. The beadboard and chalkboard should be cut to size later on.
Step 2: Assemble Frame
Picture of Assemble Frame
Once the 1x3's have been cut down to size, begin to assemble the frame using pocket holes and 1-1/4" pocket hole screws.
Step 3: Install Backs
Picture of Install Backs
Measure and cut beadboard and chalkboard to fit. I painted each prior to attaching to frame then glue in place using wood glue.
Step 4: Install Folder Holder & Hook
Picture of Install Folder Holder & Hook
Install the folder holder flush with the top of the 1x3 using wood glue and 1-1/4" brad nails. Once this folder holder is installed you can add hook centered on the 1x3 below the folder holder.
Step 5: Attach to Wall
Picture of Attach to Wall
Now that the locker is assemble, its time to attach to the wall. Install keyhole hangers to the back of the locker using 3/4" wood screws. Tighten to the point that the wood screw head fits correctly within the keyhole. Then install drywall anchors or locate stud and screw in 2" wood screw. Now its time to hang your wall locker.
Step 6: More Projects
Picture of More Projects
For more awesome DIY projects be sure to visit rogueengineer.com where we have tons of free DIY furniture and decor plans.
savageeuge (author)2016-10-06
Hey if that wall is an inside wall you could open up the drywall and put a locker between the studs and hang that frame on a piano hinge which would be strong enough to hold the back pack. Even if you put the hanger at the hinge.
Richafix (author)2016-09-26
Excellent project, well done. Glad to see the use of a splitter and push stick on the table saw.
bhushant5 (author)2016-09-25
solved my problem.
IvoryBot (author)2016-09-25
beautiful, simply, classy, and not to big that it takes up to much space, therefore looking awkward hanging on the wall. I truly love this piece. It resolves all the kid(s) school organized needs. Thank you so much for sharing!
reisebett (author)2016-09-23
wow so easy
seamster (author)2016-09-22
I like it. Simple, organized and clean. Well done!
Rogue Engineer (author)seamster2016-09-22
Thanks!
About This Instructable
11,766views
200favorites
License:
More by Rogue Engineer:How to Build a Wall Locker DIY Moroccan Side Table DIY Chalkboard Tombstones
Add instructable to:
