How to Build a Wiremap
The Wiremap is a project that builds digital 3d objects in real 3d space. To create digital 3d objects in real 3d space, a projector is placed in front of a custom designed projection surface made up of an array of vertical wires.
If you'd like to learn more about the project in general, you can do so at the Wiremap website.
This instructable will show you how to build your own Wiremap from scratch.
Before we begin - let's just make sure that your computer system will run the programs that I've built. For windows users, download the following:
http://wiremap.phedhex.com/instructable/wiremap_instructable_windows.zip
For mac & linux, download the following:
http://wiremap.phedhex.com/instructable/wiremap_instructable_nonwin.zip
Then, go to http://www.processing.org and download the program. Processing will allow you to run the programs in the zip.
Windows - open calib_64 -> application.windows -> calib_64.exe. If you see a bunch of multicolored lines going across your whole screen, you're good.
Other OS - open calib_64.pde with processing. If you see a bunch of multicolored lines going across your whole screen, you're good.
Press escape to exit the program.
Step 1Understanding the Main Concept
Before we dive in, let's take a look at the anatomy of a Wiremap. The diagram below is a bird's eye view of a projector throwing it's light.
In regular situations, the projector hits a surface at a given distance. Pretend there is a screen at the line labeled "mapline" that the projector is hitting. Now, take that screen and cut it up into a bunch of vertical strips. By moving some strips closer towards the projector, the projector effectively projects in 3d space.
The projector is fed by a computer that has the depths of all the vertical strips memorized. Through this, we can build digital 3d objects in real space.
The Process
Learn about your projector.
Figure out how many wires you want in your wiremap.
Trace out the layout of your projection on some foam core.
Mark where you want your wires to go on that foam core.
Drop thread through those spots
Calibrate
And run your program
47 comments
1-40 of 47next »
Apr 27, 2009. 6:17 PMekuhlkamp says:
Awesome.
Jan 4, 2012. 12:17 PMKathyHOrn says:
tort
Dec 7, 2011. 3:54 PMKathyHOrn says:
I am building a wiremap for my science fair project, so i wanted to know what's the science behind this because i have look for it online but i can't get information about it.
Dec 7, 2011. 3:53 PMKathyHOrn says:
Dec 7, 2011. 3:27 PMKathyHOrn says:
Aug 13, 2011. 7:49 PMcub cub says:
I had to move the projector temporarily so I just have a picture of it without the projector shining on it. It does work though! This one has 100 strings.
Aug 9, 2011. 11:05 PMOgredude says:
I want to build one of these and hang it over the conference table at my company. I'd have a motor-driven winch to raise and lower the bottom platform to fold the screen up when it's not being used. Figure out a way to display meaningful data on it, and we'd have some really cool looking meetings!
Jul 29, 2011. 1:15 PMcub cub says:
I made one with 100 wires and it works great. I will put some pictures up next week.
Jun 15, 2011. 4:57 PMtinker234 says:
hey could i form a box and make the wires in a image for a holgram
Apr 8, 2011. 8:14 AMzachsoniasummers says:
Is it possible to display more succinct objects, such as a person or ball?
Feb 18, 2009. 9:10 AMjoxer15 says:
ill go build this. ill maybe use 640 wires (=
positioning of wires is randomly?
Jan 2, 2011. 12:42 PMimarichardson says:
Phedhex. I'm a little late to the game but really interested in this project. You mentioned that you have the Ruby code for the randomization. If you don't mind can I have access for this? Perhaps posting on github would be an option too. If you do my username is imarichardson.
Aug 21, 2009. 9:53 AMidmism says:
how do you sequence the sine surface and runs as one continuously loop in processing??
Feb 19, 2009. 12:17 AMjoxer15 says:
i am very interested in this. So i have other idea of ... In mine 3d projection each wire has exactly one position and each colum of pixels from projector will lighting on one wire in 3d table. Could you writte your email please? I would to write you. Thanks
Nov 4, 2010. 7:53 AMjerickson says:
im thinking about doing this for a school project but for us to get credit it would have to look like yours in the video. im not getting how you lay out the strings or is it random to a point?
Mar 8, 2010. 12:52 PMMillenniumMan says:
They had something like this but much more advanced on the X-men movie, and they used ferrofluids instead of wires.
Remember the simulation table when the Professor showed what would happen to New York if that magneto wave hit the city?
That is similar to this, but yours has pretty colors, not all greyish.
Sep 4, 2010. 11:01 AMcdousley says:
i think i saw one on avatar that they were using as a map. ive seen these on all kinds of movies but i never knew they were real
May 17, 2010. 4:12 AMoppemi says:
It's awesome. I'd like to build one my self. But, can you place the wires randomly around in the wire field? And what types of wires do you use, normal threads?
Aug 29, 2010. 4:03 PMFriggin Smift says:
In the download file you'll find a file that has a sort of (x,y) coordinate system for marking and drilling the holes for the wires. I suppose it would be best to use a nice white thread for this.
Jan 3, 2010. 4:14 AMSkyriam says:
This is one of the most incredible things I've ever seen, congratulations and thanks for posting! So... were you able to render cityscapes or other 3d objects like rotating cubes and such? The first thing that popped into my mind was rendering of 3d objects using SolidWorks and AutoCAD, it would be awesome to display it. Thanks!
Jan 3, 2010. 4:13 PMSkyriam says:
How was he able to do that? Lets just say I have the system ready, How would you "export" images or 3d objects into your software?  Thankss!!
Jan 23, 2010. 8:38 PMSkyriam says:
No worries my friend... Ok, I'll get in touch with him and ask him how to export 3d objects, thanks! all the best.
Feb 25, 2009. 5:05 PMmever says:
WOW!, This is top notch! Great work on the Instructable and an awesome project. I haven't had time to work on much in a while but this is something I want to play with. Thank you for taking the time to post this.
Feb 21, 2009. 11:55 AMuserhck says:
Could this be synced to music somehow?
Feb 14, 2009. 12:53 AMpinhole says:
Actually it's needless to say, but this is very cool! I wish you many more happy wiremappings !
Feb 13, 2009. 6:33 AMFuzzyBearGeek says:
You are strange. Thank god! We need more people with creative minds. Obvious, I know. Thanks for the hard work and well put together instructable.
Feb 13, 2009. 12:39 AMfrikkie says:
Oh dear I thought of something else when I read the titel of the instructable. Well it looks nice.
Feb 9, 2009. 8:15 AMdchall8 says:
This takes me back to the 1970s when you could go to a company called Heath Kit and buy a computer that you had to assemble yourself. When you got it assembled and running you could turn on the LEDs built into the computer. That's all, turn on the lights. And they sold them by the thousands!!
Feb 13, 2009. 12:28 AMteddlesruss says:
There was a kit made for an electronics magazine based on an "SC-MP" chip that did 4 bit calculation with toggle switches and front panel LEDs, I think it was called the "Mini SCaMP" or something, I built one up and that was the first computer I ever owned... How times have changed...
Feb 12, 2009. 10:32 PMmidiwall says:
Hmmm... Are you thinking about the EC-1? That was an analog computer, and could be programmed to solve problems, though nothing very practical by today's standards. :)
ref: http://www.heathkit-museum.com/computers/hvmec-1.shtml
Feb 12, 2009. 3:36 PMA good name says:
What are some applications of this? I'm not sure I really understand what it is.
Feb 11, 2009. 1:02 PMcryophile says:
Earlier I asked a question before regarding whether or not it would be possible to render complex models such as cities using this method, but it seems the board ate my comment. Also, have you tried using monofilament for your wires, or would that not work? Does the surface your are projecting onto have to be reflective, or could it have fiberoptic properities?
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:phedhex
twitter: phedhex Mailing list: http://www.phedhex.com/mailing_list/
