Step 5Assemble and Install Legs
Insert the leg into a 20-6 fitting that is a part of the top rectangle.
Slip-on the first MH50 onto your shelf mark and tighten the set screw.
Slip-on the second MH50 onto your second shelf mark and tighten the set screw.
Attach the 61-6 Flange the bottom of the leg and tighten the set screw.
Repeat this four times.
NOTE: your legs may initially be somewhat crooked. To rectify this tip the bench over on it's legs and adjust the how far some of the pipe is going into the fittings. You can do this by loosening and re-tightening the set screw.
Add Comment
