Note: If you’re new to earthbag building, first read the introductory Step-by-Step Earthbag Building Instructable and How to Build an Earthbag Roundhouse . Also, my new Earthbag Building Guide and Earthbag Building DVD are now available.
We built this earthbag dome at our home in Thailand for Mother Earth News Magazine in 2007. The article that describes the complete building process in detail was published August/September 2009. It is now free on the Internet: Low-Cost Multipurpose Minibuilding Made With Earthbags , by Owen Geiger.
This earthbag dome Instructable simplifies the process and illustrates each step of construction with photos. The two critical drawings are also included here. Please refer to the complete article before asking questions.
This multi-purpose dome can serve as a storage shed or cool pantry above ground, or as a rootcellar or storm shelter below ground. No building permit is typically needed, because it is below the minimum size required by building codes, is not inhabited and is not attached to a residence.
Earthbag structures provide a cool space in summer and an escape from the cold in winter (ideal for humans and animals), which means this earthbag dome is well suited for many purposes, like a quiet space for relaxing or playing music, as well as those listed previously. Depending on your needs, the most practical combination of uses might be a rootcellar/cool pantry for daily use and a disaster shelter for emergencies such as tornadoes or hurricanes.
The key concept that makes earthbag domes work is corbelling. This means each course (each row) of bags is inset slightly from the course below. Corbelled domes made of adobe and stone have been built for thousands of years. The concept has been applied to earthbags in the last few decades.
Basic project information:
18’ exterior diameter; 8’ interior diameter; 11’ exterior diameter, 50 sq. ft. interior floor space; total cost of materials: $300, which is about $6/square foot.
Tools:
Tamper(s), round nose shovel(s), grape hoe or grub hoe (digging tool), 13” x 16” sheetmetal slider, knife, hammer, 2’ level, 2” x 4” x 10’ leveling board, tape measure, fencing pliers, handsaw, trowel, garden hose with spray nozzle, 6’ or 8’ stepladder
The following instructions assume you have cleared and leveled the site, removed topsoil, positioned fill soil around the building site to minimize work, dug a trench to stable subsoil, put about 12” of gravel in the trench, and added two stakes with string lines: a center stake with string line to measure the radius, and a stake in front of the door to measure the dome curvature. Bags or tubes can be used. We demonstrate bags, because they’re often available recycled for very low cost. My YouTube Channel has a short video showing how the dome was built.
Remove these ads by
Signing UpStep 1Dome Plans
Let’s briefly take a look at the plans so you’ll better understand the building process. The first drawing is the floorplan that shows the dimensions for the dome base and the angled buttresses in front. The buttresses provide reinforcing on both sides of the door and also act as retaining walls to hold back the earth. Make a rubble trench under the buttresses the same as the dome, and interlock (overlap) each course where the dome and buttresses intersect.
The second drawing is the dome section that shows key vertical dimensions, earthbag foundation, door and arch. Note the wood stake in front of the door. The string line on this stake guides the curvature of the dome (112” radius in this case). This dimension remains constant. Put the stake off to one side of the doorway so you’re not tripping on it during construction.
,I'm sure it's possible but curious about your thoughts ?
Be sure to check out our earthbag blog and other websites for complete info.
http://earthbagbuilding.wordpress.com/
But you can't build an earthbag wall or other heavy wall the way you describe or the sides would collapse.
Thank you for sharing this... It´s beautiful! I am going to build my own house soon and this method looks very interesting.
Love frome chile!
Eugenio
Be that as it may, I'm thinking an alternate construction technique that might be quite a bit less labor intensive would be to create a large compacted mound of the correct dirt type using a front loader, then progressively hollow it out while reinforcing using standard tunneling/mining techniques, then finish up with a layer of sprayed in rebar'd concrete on the interior if so desired. If a layer of gravel could somehow be engineered between the concrete and the dirt you'd get nice drainage to the periphery and leaks would be minimized. I just can't help thinking about all the plastic for the dirt bags and the 6 mil for preventing leaks and how it might be avoided. Gravel drains nicely generally.
You can also combine earthbags with ferrocement to insulate the building. I've been describing my ideas on how to do this on our Earthbag Building Blog: http://earthbagbuilding.wordpress.com/
You can fill the bags with various types of insulation. Or you can fill bags or tubes with geopolymer. The bags or tubes are stacked next to the ferrocement frame and tied to it. The geopolymer can be lightweight and insulating. http://earthbagbuilding.wordpress.com/2011/09/23/lightweight-insulating-geopolymer-earthbags-part-3/
